Updated on 2025-11-14 GMT+08:00
Creating a Manual Backup
TaurusDB for PostgreSQL allows you to create manual backups for an available DB instance. You can use these backups to restore data.
  • When you delete a DB instance, its automated backups are also deleted but its manual backups are retained.
  • You can create manual backups only when your account balance is no less than $0 USD.
  • The backup name must be unique.
Billing
Backups are saved as packages in OBS buckets.
Method 1
  2. Click in the upper left corner and select a region.
  3. Click in the upper left corner of the page and choose Databases > TaurusDB.
  4. On the Instances page, locate the target DB instance and choose More > Create Backup in the Operation column.
  5. In the displayed dialog box, enter a backup name and description. Then, click OK.
    • The backup name can contain 4 to 64 characters and must start with a letter. Only letters (case-sensitive), digits, hyphens (-), and underscores (_) are allowed.
    • The backup description can consist of a maximum of 256 characters and cannot contain carriage return characters or the following special characters: >!<"&'=
    • The time required for creating a manual backup depends on the amount of data.
    To check whether the backup has been created, you can click in the upper right corner of the page to check the DB instance status. If the DB instance status becomes Available from Backing up, the backup has been created.
  6. View and manage the created backup on the Backups page.
    Alternatively, click the instance name. On the Backups page, you can view and manage the manual backup.
Method 2
  4. On the Instances page, click the instance name.
  5. On the Backups page, click Create Backup. In the displayed dialog box, enter a backup name and description and click OK.
