Help Center/ TaurusDB_TaurusDB for PostgreSQL/ User Guide/ Instance Modifications/ Changing the Failover Priority
Updated on 2026-02-06 GMT+08:00
TaurusDB for PostgreSQL allows you to change the failover priority for primary and standby instances. You can select reliability or availability.
- Reliability (default setting): Data consistency is preferentially ensured during a primary/standby failover. This is recommended for applications whose highest priority is data consistency. In extreme scenarios, there may be a small amount of data lost if your instance uses asynchronous replication.
- Availability: Database availability is preferentially ensured during a primary/standby failover. This is recommended for applications that require databases to provide uninterrupted online services.
The failover priority cannot be changed when the DB instance is stopped.
- Click
in the upper left corner and select a region. - Click
in the upper left corner of the page and choose Databases > TaurusDB. - On the Instances page, locate a primary/standby instance and click the instance name.
- On the displayed Basic Information page, find Failover Priority and click Modify under it. In the displayed dialog box, select a priority and click OK. Figure 1 Changing the failover priority
- View the results on the Basic Information page.
