Help Center/ TaurusDB_TaurusDB for PostgreSQL/ User Guide/ Instance Modifications/ Changing the Replication Mode
Updated on 2026-02-06 GMT+08:00
TaurusDB for PostgreSQL allows you to change the replication mode between primary and standby instances. Data can be asynchronously or synchronously replicated from the primary instance to the standby instance.
- Asynchronous (default): When an application writes data to the primary instance, the primary instance returns a response to the application immediately without waiting for the standby instance to receive logs.
- Advantages: Asynchronous replication involves low overhead and ensures that write operations are not blocked during a failover of your primary/standby instances.
- Disadvantages: In rare cases, replication is delayed between the primary and standby instances, and data may be lost after the failover.
- Synchronous: When an application writes data to the primary instance, the primary instance returns a response to the application only after the standby instance receives logs (which are flushed to the disk).
- Advantages: Data remains strongly consistent between the primary and standby instances, and no data loss occurs after a failover.
- Disadvantages: Synchronous replication involves high overhead and causes write operations to be blocked when the primary or standby instance is faulty.
- Asynchronous replication is recommended for applications requiring a guarantee of high availability.
- Synchronous replication is recommended for applications that require strong data consistency and can tolerate a short-time blocking of write operations.
- Write operations refer to non-SELECT operations, such as DDL and DML.
- Click
in the upper left corner and select a region. - Click
in the upper left corner of the page and choose Databases > TaurusDB. - On the Instances page, locate a primary/standby instance and click the instance name.
- On the displayed Basic Information page, find Synchronize Model and click Modify under it. In the displayed dialog box, select a mode and click OK.
- View the results on the Basic Information page.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
