Updated on 2025-11-14 GMT+08:00
Exporting DB Instance Information
You can export information about all or selected DB instances to view and analyze DB instance information.
A tenant can export a maximum of 3,000 instances at a time. The time required for the export depends on the number of instances.
Exporting Information About All DB Instances
  2. Click in the upper left corner and select a region.
  3. Click in the upper left corner of the page and choose Databases > TaurusDB.
  4. On the Instances page, click Export Instance Info above the DB instance list. By default, information about all DB instances is exported. In the displayed dialog box, you can select the items to be exported and click OK.
  5. Find a .csv file locally after the export task is completed.
Exporting Information About Selected DB Instances
  4. On the Instances page, filter DB instances by DB engine, DB instance name, DB instance ID, private IP address, or enterprise project, or select the DB instances to be exported, and click Export Instance Info above the DB instance list. In the displayed dialog box, select the items to be exported and click OK.
