Updated on 2025-11-14 GMT+08:00
Selecting Displayed Items
You can customize which instance items are displayed on the Instances page.
  2. Click in the upper left corner and select a region.
  3. Click in the upper left corner of the page and choose Databases > TaurusDB.
  4. On the Instances page, click to edit columns displayed in the DB instance list.
    • Table Text Wrapping: If you enable this function, excess text will move down to the next line.
    • Operation Column: If you enable this function, the Operation column is always fixed at the rightmost position of the table.
    • The following items can be displayed: Name/ID, Description, DB Instance Type, DB Engine Version, Status, Billing Mode, Private IP Address, Private IP Address for Read, Proxy Address, Private Domain Name, Enterprise Project, Created, Database Port, Storage Type, and Operation.
