Updated on 2025-11-14 GMT+08:00
Starting a DB Instance
You can stop your instance temporarily to save money. After stopping your instance, you can restart it to begin using it again.
Billing
After a DB instance is started, the VM where the DB instance is located is billed again.
  • When a stopped DB instance is started, a full backup is automatically triggered.
  • Only instances in Stopped state can be started.
  • A stopped pay-per-use instance may fail to start due to insufficient ECS resources. If this happens, try again later. If you need assistance, submit a service ticket.
  2. Click in the upper left corner and select a region.
  3. Click in the upper left corner of the page and choose Databases > TaurusDB.
  4. On the Instances page, locate the primary instance that you want to start and choose More > Start in the Operation column.
  5. In the displayed dialog box, click OK.
    Figure 1 Starting a DB instance
  6. Refresh the instance list and view the status of the instance. If the status is Available, the instance is started successfully.
