Updated on 2025-11-28 GMT+08:00
Viewing Instance Overview Data
You can view instance overview data to learn about the statuses and alarms of DB instances in real time.
Learning About TaurusDB for PostgreSQL
If you are new to TaurusDB for PostgreSQL, you can quickly learn about its concepts, common functions, and how to purchase and get started with a DB instance by referring to Progressive Knowledge.
  1. To purchase a TaurusDB for PostgreSQL instance, click Buy DB Instance on the Overview page and select your desired version and specifications. For details, see Buying a TaurusDB for PostgreSQL Instance.
  2. After the purchase is complete, view the instance status and active alarms on the Overview page.
Viewing Instances by Status
The statuses of all TaurusDB for PostgreSQL instances under your account are displayed in the upper part of the Overview page.
Table 1 Status description
Item
Total instances
Total number of TaurusDB for PostgreSQL instances in all states
Abnormal
Total number of TaurusDB for PostgreSQL instances in the Abnormal state
Frozen
Total number of TaurusDB for PostgreSQL instances in the Frozen state
Pending reboot
Total number of TaurusDB for PostgreSQL instances in the Pending reboot state
Modifications to some parameters require an instance reboot before they can be applied.
Available
Total number of TaurusDB for PostgreSQL instances in the Available state
Newly purchased
Total number of TaurusDB for PostgreSQL instances purchased in the last seven days
