Creating a Database Account
When you create a DB instance, account root is created at the same time by default. You can create other database accounts as needed.
- The instance must be in the running state.
- This operation is not allowed for DB instances that are being restored.
- Click
in the upper left corner and select a region. - Click
in the upper left corner of the page and choose Databases > TaurusDB. - On the Instances page, click the instance name.
- On the Accounts page, click Create Account.
- In the displayed dialog box, set required parameters and click OK. Figure 1 Creating a database account
Table 1 Parameter description Parameter
Username
The username can contain 1 to 32 characters. It can include letters, digits, and underscores (_). It cannot start with pg or a digit and must be different from the system usernames. System users include rdsAdmin, rdsMetric, rdsBackup, rdsRepl, rdsProxy, rdsDdm, and rdsDisaster.
- rdsAdmin: a management account with the highest permission. It is used to query and modify instance information, rectify faults, migrate data, and restore data.
- rdsRepl: a replication account. It is used to synchronize data from a primary instance to its standby instance or read replicas.
- rdsBackup: a backup account. It is used to back up data in the background.
- rdsMetric: a metric monitoring account. It is used by watchdog to collect database status data.
- rdsProxy: a database proxy account, used for authentication when the database is connected through a proxy address. This account is automatically created when you enable read/write splitting.
- rdsDdm: a DDM account.
- rdsDisaster: a DR account. It is used to set up cross-region DR.
Password
- The password must consist of 8 to 32 characters and contain at least three types of the following characters: uppercase letters, lowercase letters, digits, and special characters (~!@#$%^*-_=+?,).
- The password cannot contain the username or the username spelled backwards.
- The password must be strong to avoid being easily cracked, as weak passwords will block the creation of your account. You are advised to enter a strong password to improve security and prevent security risks such as brute force cracking.
Permission
You can assign permissions, including CREATEDB, CREATEROLE, and REPLICATION, to the user.
- CREATEDB: indicates that the user has the permission to create a database. If this attribute is not specified, the user cannot create databases by default.
- CREATEROLE: indicates that the user has the permission to create other users. If this attribute is not specified, the user cannot be used to create new users by default.
- REPLICATION: indicates that the user can use streaming replication or logical replication. If this attribute is not specified, the user cannot be used to set up streaming replication or logical replication by default.
The description can contain 0 to 512 characters.
- After the account is created, manage it on the Accounts page.
Privileges of the Root User
TaurusDB for PostgreSQL provides privileges for the root user. To create objects on a TaurusDB for PostgreSQL database without operation risks, escalate your account to root privileges when necessary.
The following table describes root privilege escalation in different versions.
| Version | Whether to Escalate Privileges | Initial Version for Privilege Escalation |
| pgcore16 | Yes | 16.2 |
Escalate to root privileges when you need to:
- Create an event trigger.
- Create a wrapper.
- Create a logical replication publication.
- Create a logical replication subscription.
- Query and maintain replication sources.
- Create a replication user.
- Create a full-text index template and parser.
- Run the vacuum command on a system catalog.
- Run the analyze command on a system catalog.
- Create an extension.
- Grant an object permission to a user.
Creating a Common Babelfish User
After connecting to the TDS port of a TaurusDB for PostgreSQL instance with Babelfish enabled, you can create a common Babelfish user.
- Connect to an instance through the TDS port.
sqlcmd -S <host>,1433 -U babelfish_user
- Create a common user. For more information, see CREATE USER (Transact-SQL).
-- Create a login. CREATE LOGIN test_babelfish_login WITH PASSWORD = '***'; GO
-- Creates a user for the login. CREATE USER test_babelfish_user FOR LOGIN test_babelfish_login; GO
