SWR Resources
A resource is an object that exists within a service. SWR resources include repo and namespace. You can select these resources by specifying their paths.
        Resource  |
        Resource Name  |
        Path  |
        repo  |
        Image repository  |
        [Format] swr:*:*:repo:image repository name The first * is regionid, and the second * is domainid. [Note] IAM automatically generates the path prefix SWR:*:*:repo:. For the path of a specific repository, add the image repository name to the end. You can also use a wildcard character (*) to indicate any image repository. Example: swr:*:*:repo:test/nginx*: image repository whose name starts with nginx in the test organization swr:*:*:repo:test/nginx: image repository whose name is nginx in the test organization  |
        namespace  |
        Organization  |
        [Format] SWR:*:*:namespace:organization name The first * is regionid, and the second * is domainid. [Note] For the path of an organization, IAM automatically generates the resource path prefix SWR:*:*:namespace:. You can add the organization name to the end. You can also use a wildcard character (*) to indicate any organization. Example: swr:*:*:namespace:test*: organization whose name starts with test swr:*:*:namespace:test: organization whose name is test  |
