Help Center/
SoftWare Repository for Container/
User Guide (Basic Edition)/
Auditing/
Viewing a Trace
Updated on 2025-11-14 GMT+08:00
Viewing a Trace
Once enabled, CTS starts recording operations performed on SWR resources and stores the operation records generated within a week.
This section describes how to view an operation record in the last week on the CTS console.
- Click
in the upper left corner to select the desired region. - Click Service List, and choose Management & Governance > Cloud Trace Service.
- In the navigation pane, choose Trace List.
- In the time range drop-down list in the upper left of the trace list, select a desired query time range: Last 1 hour, Last 1 day, or Last 1 week. You can also select Custom to specify a custom time range within the last seven days.
- On the Trace List page, use filters to query traces. You can combine one or more filters and then press Enter. Set basic information as follows:
- Cloud Service: indicates the name and abbreviation of a cloud service. Select SWR.
- Trace Name: indicates the name of a trace. For details about the supported trace names, see Table 1.
- Resource Name: indicates the name of the cloud resource involved in a trace.
- Operator: Select one or more operators from the drop-down list.
- Trace Status: Select normal, warning, or incident.
- normal: The operation succeeded.
- warning: The operation failed.
- incident: The operation caused a fault that is more serious than a normal failure, for example, causing other faults.
- Click the trace name to view its details.
