Sharing a Private Image
You can share your private images with other accounts and grant them permission to pull the images.
A user under these accounts can then log in to the SWR console to check these images on the My Images > Images From Others page. The user can also click the name of an image to check its details, including the image tag and image pull command.
- Only private images can be shared. Public images cannot be shared.
- Only IAM users authorized to manage the private images can share images. The users with whom you share your images only have the read-only permission, which only allows them to pull the images.
- You can share images only with accounts in the same region. Cross-region image sharing is not supported.
- A private image can be shared with a maximum of 500 tenants.
- Log in to the SWR console.
- In the navigation pane, choose My Images. Then click the name of the target image.
- On the details page, click the Sharing tab.
- Click Share Image. Set parameters based on Table 1, and click OK.
Figure 1 Sharing an image
Table 1 Sharing an image Parameter
Share With
Enter an account name.
Valid Until
Set a validity period. If you want the image to be permanently accessible to the account, select Permanently valid.
Permission
Only Pull is available currently.
0 to 1,000 characters are allowed.
- To view all the shared images, choose My Images in the navigation pane, click the Private Images tab, and select My shared images.
To share multiple images, choose My Images > Private Images, select the images, and click Share.
