Updated on 2025-11-24 GMT+08:00
Organization Management
Organizations are used to isolate image repositories. With each organization being limited to one company or department, images can be managed in a centralized and efficient manner. An image name needs to be unique within an organization. The same IAM user can access different organizations as long as the user has sufficient permissions, as shown in Figure 1.
You can grant different permissions, namely, read, edit, and manage, to IAM users under the same account. For details, see Granting Permissions for Images.
Figure 1 Organizations
Video Tutorial
Creating an Organization
You can create organizations based on the organizational structure of your enterprise to facilitate image resource management. Create an organization before you push an image.
  1. Log in to the SWR console.
  2. Click in the upper left corner and select a region and project.
  3. Choose Organizations in the navigation pane.
  4. Click Create Organization in the upper right corner of the page. In the displayed dialog box, enter a name and click OK.
    • The organization name must be unique in the current region. If a message is displayed indicating that the organization already exists, the organization name may have been used by another user. Use another organization name.
    • A user can create organizations only after being assigned with the SWR Admin or Tenant Administrator policy in IAM.
    • The organization name cannot be library, which is reserved for the system.
Viewing Images of an Organization
After you create an organization and push images to it, you can view these images in the organization.
  3. In the navigation pane, choose Organizations. Then click the name of the target organization in the list.
  4. To view the images of this organization, click the Images tab.
Deleting an Organization
Before deleting an organization, delete all images from the organization.
  4. Locate an organization. In the upper right corner of the organization, click Delete. Then, click OK.
