Updated on 2025-11-18 GMT+08:00
Software Versions Required by Different Models
You can use elastic BMSs or ECSs as the node resources in the elastic cluster resource pool. The OSs and CCE cluster versions vary depending on the node model. This section describes the software versions required by different models, which helps you create images and upgrade software.
Software Versions Required by BMSs
Table 1 BMS
Type
PU Type
RDMA Network Protocol
OS
Applicable Scope
Dependent Plug-in
NPU
ascend-snt9b
RoCE
  • OS: EulerOS 2.10 64-bit (recommended)
  • Kernel version: 4.19.90-vhulk2211.3.0.h1543.eulerosv2r10.aarch64
  • Architecture type: aarch64
  • Cluster type: CCE Standard
  • Cluster version: v1.23 (v1.23.5-r0 or later), v1.25, v1.28, or v1.31 (recommended)
  • Cluster scale: 50, 200, 1000, or 2000
  • Cluster network mode: container tunnel network or VPC
  • Cluster forwarding mode: iptables or ipvs
  • huawei-npu
  • npu-driver
  • volcano
For details about the plug-in version mapping, see Table 4.
RoCE
  • OS: Huawei Cloud EulerOS 2.0 64-bit
  • Kernel version: 5.10.0-60.18.0.50.r865_35.hce2.aarch64
  • Cluster type: CCE Turbo
  • Cluster version: v1.23, v1.25, v1.28, or v1.31 (recommended)
  • Cluster network mode: ENI
ascend-snt9
RoCE
  • OS: EulerOS 2.8 64-bit
  • Kernel version: 4.19.36-vhulk1907.1.0.h619.eulerosv2r8.aarch64
  • Cluster type: CCE Standard or Turbo
  • Cluster version: v1.23 (v1.23.5-r0 or later), v1.25, or v1.28 (recommended)
  • Cluster network mode: container tunnel network, VPC, or ENI
GPU
gpu-ant8
RoCE
  • Kernel version: 4.18.0-147.5.2.15.h1109.eulerosv2r10.x86_64
  • Architecture type: x86
    Distributed training only supports container tunnel network.
  • gpu-beta
  • gpu-driver
  • rdma-sriov-dev-plugin
gpu-ant1
RoCE
  • 4.18.0-147.5.2.15.h1109.eulerosv2r10.x86_64
gpu-vnt1
RoCE|IB
  • OS: EulerOS 2.9 64-bit (recommended)
  • Kernel version: 4.18.0-147.5.1.6.h841.eulerosv2r9.x86_64
  • Remote direct memory access (RDMA) is a direct memory access from the memory of one computer into that of another without involving either one's operating system.
  • RDMA over Converged Ethernet (RoCE) is a network protocol which allows RDMA over an Ethernet network.
  • InfiniBand (IB) is a computer networking communications standard used in high-performance computing. It is used for data interconnect both among and within computers.
Software Versions Required by ECSs
Table 2 ECS
Type
PU Type
OS
Applicable Scope
Dependent Plug-in
NPU
ascend-snt3p-300i
  • Architecture type: x86 or Arm
  • os-node-agent
  • volcano
  • huawei-npu
  • npu-driver
  • OS: EulerOS 2.9
  • huawei-npu
  • npu-driver
  • volcano
ascend-snt3
  • OS: EulerOS 2.5
  • Cluster version: v1.23 or v1.25
  • OS: EulerOS 2.8
  • Architecture type: Arm
ascend-snt9b
GPU
gpu-vnt1
  • OS: EulerOS 2.9
  • gpu-beta
  • gpu-driver
gpu-ant03
  • OS: EulerOS 2.9
gpu-ant1-pcie40
  • OS: EulerOS 2.9
gpu-tnt004
  • OS: EulerOS 2.9
Mapping Between Drivers, Plug-in Versions, and CCE Cluster Versions
Table 3 Mapping between driver and CCE cluster versions
Type
Plug-in
Plug-in Version
Matched CCE Cluster Version
Applicable Scope
Plug-in Function
npuDriver
npu-driver
7.5.0.5.220-24.1.0.3 (recommended)
7.1.0.9.220-23.0.6
None
NPU (snt9b)
Upgrades and rolls back NPU drivers.
gpuDriver
gpu-driver
515.65.01 (recommended)
510.47.03
470.182.03
470.57.02
None
GPU
Upgrades and rolls back GPU drivers. The plug-in depends on the gpu-beta version.
Table 4 Mapping between plug-in versions and CCE cluster versions
Plug-in
Plug-in Version
Applicable Scope
Plug-in Function
gpu-beta
2.8.4 (recommended)
v1.(28|29|30|31|32).*
GPU
Allows containers to use GPU devices.
2.7.63
v1.(28|29|30|31).*
2.7.58
v1.(28|29|30|31).*
huawei-npu
2.1.53 (recommended)
v1.(25|27|28|29|30|31).*
NPU
Allows containers to use Huawei NPU devices.
2.1.47
v1.(21|23|25|27|28|29|30|31).*
volcano
1.18.3 (recommended)
v1.(27|28|29|30|31|32).*
NPU
Kubernetes-based batch processing platform.
1.17.11
v1.(25|27|28|29|30|31|32).*
os-node-agent
7.3.0
None
None
OS plug-in, which is used for fault detection.
icagent
default
The matched CCE version is installed by default.
None
CCE basic component, which is used for logging and monitoring.
