AI Suite (ModelArts Device Plugin)
The AI suite, ModelArts Device Plugin, is a device management plug-in in containers.
- When you create a dedicated resource pool, this plug-in is automatically installed only when the instance specification type is set to NPU.
- Job scheduling will be affected if you upgrade this plug-in when creating a notebook instance, creating a training job, deploying a real-time service, or deploying a batch service.
Components
Component |
Description |
Resource Type |
modelarts-device-plugin |
Allows containers to use ModelArts Device Plugin devices. |
DaemonSet |
Change History
Plug-in Version |
New Feature |
7.3.0 |
Kubernetes v1.31 is supported. |
7.2.0 |
Kubernetes v1.31 is supported. A2 single-PU multi-pods are supported. |
7.0.1 |
7.0.0 |
2.7.63 |
Fixed security vulnerabilities. |
2.7.42 |
2.1.23 |
Fixed some issues. |
2.1.22 |
2.1.5 |
1.2.15 |
v1.23 clusters are supported. |
1.2.14 |
Supported NPU monitoring. |
1.2.5 |
Supported automatic installation of NPU drivers. |
