Installing and Configuring Grafana on a Notebook Instance
This section describes how to install and configure Grafana in ModelArts Standard notebook instances.
- Run the following commands in sequence in your terminal to download and install Grafana:
mkdir -p /home/ma-user/work/grf
cd /home/ma-user/work/grf
wget https://dl.grafana.com/oss/release/grafana-9.1.6.linux-amd64.tar.gz
tar -zxvf grafana-9.1.6.linux-amd64.tar.gz
- Register Grafana with jupyter-server-proxy.
- Run the following commands in your terminal:
mkdir -p /home/ma-user/.local/etc/jupyter
vi /home/ma-user/.local/etc/jupyter/jupyter_notebook_config.py
- In jupyter_notebook_config.py, add the following code, press Esc to exit, and type :wq to save the changes:
c.ServerProxy.servers = { 'grafana': { 'command': ['/home/ma-user/work/grf/grafana-9.1.6/bin/grafana-server', '--homepath', '/home/ma-user/work/grf/grafana-9.1.6', 'web'], 'timeout': 1800, 'port': 3000 } }
If jupyter_notebook_config.py (path: /home/ma-user/.local/etc/jupyter/jupyter_notebook_config.py) contains the c.ServerProxy.servers field, add the corresponding key-value pair.
- Modify the URL for accessing Grafana in JupyterLab.
- In the navigation pane on the left, open the vi /home/ma-user/work/grf/grafana-9.1.6/conf/defaults.ini file.
- Change the root_url and serve_from_sub_path fields in [server].
Figure 1 Modifying the defaults.ini file
In the file:
- The value of root_url is in the format of https:{JupyterLab domain name}/{Instance ID}/grafana. You can obtain the domain name and instance ID from the address box of the JupyterLab page.
- Set Serve_from_sub_path to true.
- Save the image of the notebook instance.
- Log in to the ModelArts console. In the navigation pane on the left, choose Development Workspace > Notebook. On the displayed page, locate the target instance, and choose More > Save Image in the Operation column.
- In the displayed dialog box, configure the organization, image name, image version, and description, and click OK.
- The image will be saved as a snapshot, and it will take about 5 minutes. During this period of time, do not perform any operations on the instance.
- After the image is saved, the instance status changes to Running. Then, restart the notebook instance.
- Open the Grafana page.
Open a browser window and type the value of root_url configured in 3 in the address box. If the Grafana login page is displayed, Grafana is installed and configured in the notebook instance. The default username and password for the first login are admin. After the login is successful, change the password as prompted.
