Help Center/ ModelArts/ ModelArts User Guide (Standard)/ Resource Monitoring/ Viewing All ModelArts Monitoring Metrics on the AOM Console
Updated on 2024-12-26 GMT+08:00
ModelArts periodically collects the usage of key metrics (such as GPUs, NPUs, CPUs, and memory) of each node in a resource pool as well as the usage of key metrics of development environments, training jobs, and inference services, and reports the data to AOM. You can view the information on AOM.
Viewing Monitoring Metrics on the AOM Console
  1. Log in to the console and search for AOM to go to the AOM console.
  2. In the navigation pane on the left, choose Metric Browsing.
  3. Select the Prometheus_AOM_Default instance from the drop-down list.
    Figure 1 Specifying the metric source
  4. Select one or more metrics from All metrics or Prometheus statement.
    Figure 2 Adding a metric
    For details about how to view metrics, see Application Operations Management > User Guide (2.0) > Metric Browsing in the Huawei Cloud Help Center.
Container-level Metrics
Table 1 Container metrics
Category
Name
Metric
Unit
Value Range
Alarm Threshold
Alarm Severity
Solution
CPU
CPU Usage
ma_container_cpu_util
CPU usage of a measured object
0%–100%
Raw data > 95% for two consecutive periods
Suggestion
Check whether the service resource usage meets the expectation. If the service is normal, no action is required.
Used CPU Cores
ma_container_cpu_used_core
Number of CPU cores used by a measured object
Cores
≥ 0
N/A
N/A
N/A
Total CPU Cores
ma_container_cpu_limit_core
Total number of CPU cores that have been applied for a measured object
Cores
≥ 1
N/A
N/A
N/A
CPU Memory Usage
ma_container_gpu_mem_util
Percentage of the used GPU memory to the total GPU memory
0%–100%
Suggestion
Memory
Total Physical Memory
ma_container_memory_capacity_megabytes
Total physical memory that has been requested for a measured object
MB
≥ 0
N/A
N/A
N/A
Physical Memory Usage
ma_container_memory_util
Percentage of the used physical memory to the total physical memory
0%–100%
Suggestion
Used Physical Memory
ma_container_memory_used_megabytes
Physical memory that has been used by a measured object (container_memory_working_set_bytes in the current working set)
(Memory usage in a working set = Active anonymous page and cache, and file-baked page ≤ container_memory_usage_bytes)
MB
≥ 0
N/A
N/A
N/A
Disk Read Rate
ma_container_disk_read_kilobytes
Volume of data read from a disk per second
KB/s
≥ 0
N/A
N/A
N/A
Disk Write Rate
ma_container_disk_write_kilobytes
Volume of data written into a disk per second
KB/s
≥ 0
N/A
N/A
N/A
GPU memory
Total GPU Memory
ma_container_gpu_mem_total_megabytes
Total GPU memory of a training job
MB
> 0
N/A
N/A
N/A
GPU Memory Usage
0%–100%
N/A
N/A
N/A
Used GPU Memory
ma_container_gpu_mem_used_megabytes
GPU memory used by a measured object
MB
≥ 0
N/A
N/A
N/A
Idle GPU Memory
ma_container_gpu_mem_free_megabytes
Idle GPU memory of a measured object
MB
≥ 0
N/A
N/A
N/A
GPU
GPU usage
ma_container_gpu_util
GPU usage of a measured object
0%–100%
Suggestion
GPU Memory Bandwidth Usage
ma_container_gpu_mem_copy_util
GPU memory bandwidth usage of a measured object For example, the maximum memory bandwidth of GP Vnt1 is 900 GB/s. If the current memory bandwidth is 450 GB/s, the memory bandwidth usage is 50%.
0%–100%
N/A
N/A
N/A
GPU Encoder Usage
ma_container_gpu_enc_util
GPU encoder usage of a measured object
N/A
N/A
N/A
GPU Decoder Usage
ma_container_gpu_dec_util
GPU decoder usage of a measured object
N/A
N/A
N/A
GPU Temperature
DCGM_FI_DEV_GPU_TEMP
GPU temperature
°C
Natural number
N/A
N/A
N/A
GPU Power
DCGM_FI_DEV_POWER_USAGE
GPU power
Watt (W)
> 0
N/A
N/A
N/A
GPU Memory Temperature
DCGM_FI_DEV_MEMORY_TEMP
GPU memory temperature
°C
Natural number
N/A
N/A
N/A
Network I/O
Downlink Rate
ma_container_network_receive_bytes
Inbound traffic rate of a measured object
Bytes/s
≥ 0
N/A
N/A
N/A
Packet RX Rate
ma_container_network_receive_packets
Number of data packets received by an NIC per second
Packets/s
≥ 0
N/A
N/A
N/A
Downlink Error Rate
ma_container_network_receive_error_packets
Number of error packets received by a NIC per second
Packets/s
≥ 0
Raw data > 1 for two consecutive periods
Critical
Packet loss on the network. Submit a service ticket and contact the O&M support to locate the fault.
Uplink Rate
ma_container_network_transmit_bytes
Outbound traffic rate of a measured object
Bytes/s
≥ 0
N/A
N/A
N/A
Uplink Error Rate
ma_container_network_transmit_error_packets
Number of error packets sent by a NIC per second
Packets/s
≥ 0
Critical
Packet TX Rate
ma_container_network_transmit_packets
Number of data packets sent by a NIC per second
Packets/s
≥ 0
N/A
N/A
N/A
NPU
NPU Usage
ma_container_npu_util
NPU usage of a measured object (To be replaced by ma_container_npu_ai_core_util)
0%–100%
Suggestion
NPU Memory Usage
ma_container_npu_memory_util
Percentage of the used NPU memory to the total NPU memory (To be replaced by ma_container_npu_ddr_memory_util for Snt3 series, and ma_container_npu_hbm_util for Snt9 series)
0%–100%
Raw data > 98% for two consecutive periods
Suggestion
Used NPU Memory
ma_container_npu_memory_used_megabytes
NPU memory used by a measured object (To be replaced by ma_container_npu_ddr_memory_usage_bytes for Snt3 series, and ma_container_npu_hbm_usage_bytes for Snt9 series)
≥ 0
MB
N/A
N/A
N/A
Total NPU Memory
ma_container_npu_memory_total_megabytes
Total NPU memory of a measured object (To be replaced by ma_container_npu_ddr_memory_bytes for Snt3 series, and ma_container_npu_hbm_bytes for Snt9 series)
> 0
MB
N/A
N/A
N/A
AI Processor Error Codes
ma_container_npu_ai_core_error_code
Error codes of Ascend AI processors
Raw data > 0 for three consecutive periods
Critical
Abnormal card. Submit a service ticket and contact the O&M support.
AI Processor Health Status
ma_container_npu_ai_core_health_status
Health status of Ascend AI processors
  • 1: healthy
  • 0: unhealthy
Raw data > 0 for two consecutive periods
Critical
AI Processor Power Consumption
ma_container_npu_ai_core_power_usage_watts
Power consumption of Ascend AI processors
Watt (W)
> 0
N/A
N/A
N/A
AI Processor Temperature
ma_container_npu_ai_core_temperature_celsius
Temperature of Ascend AI processors
°C
Natural number
N/A
N/A
N/A
AI Core Usage
AI core usage of Ascend AI processors
0%–100%
Suggestion
Overall NPU Usage
ma_container_npu_general_util
NPU usage of Ascend AI processors (supported by driver version 24.1.RC2 and later)
0%–100%
N/A
N/A
N/A
AI Core Clock Frequency
ma_container_npu_ai_core_frequency_hertz
AI core clock frequency of Ascend AI processors
Hertz (Hz)
> 0
N/A
N/A
N/A
AI Processor Voltage
ma_container_npu_ai_core_voltage_volts
Voltage of Ascend AI processors
Volt (V)
Natural number
N/A
N/A
N/A
AI Processor DDR Memory
Total DDR memory capacity of Ascend AI processors
Byte
> 0
N/A
N/A
N/A
AI Processor DDR Usage
DDR memory usage of Ascend AI processors
Byte
> 0
N/A
N/A
N/A
AI Processor DDR Memory Utilization
DDR memory utilization of Ascend AI processors
Invalid metric for Snt9C.
0%–100%
Suggestion
AI Processor HBM Memory
Total HBM memory of Ascend AI processors (dedicated for Snt9 processors)
Byte
> 0
N/A
N/A
N/A
AI Processor HBM Memory Usage
HBM memory usage of Ascend AI processors (dedicated for Snt9 processors)
Byte
> 0
N/A
N/A
N/A
AI Processor HBM Memory Utilization
HBM memory utilization of Ascend AI processors (dedicated for Snt9 processors)
0%–100%
Suggestion
AI Processor HBM Memory Bandwidth Utilization
ma_container_npu_hbm_bandwidth_util
HBM memory bandwidth utilization of Ascend AI processors (dedicated for Snt9 processors)
0%–100%
Suggestion
AI Processor HBM Memory Clock Frequency
ma_container_npu_hbm_frequency_hertz
HBM memory clock frequency of Ascend AI processors (dedicated for Snt9 processors)
Hertz (Hz)
> 0
N/A
N/A
N/A
AI Processor HBM Memory Temperature
ma_container_npu_hbm_temperature_celsius
HBM memory temperature of Ascend AI processors (dedicated for Snt9 processors)
°C
Natural number
N/A
N/A
N/A
AI CPU Utilization
ma_container_npu_ai_cpu_util
AI CPU utilization of Ascend AI processors
0%–100%
N/A
N/A
N/A
AI Processor Control CPU Utilization
ma_container_npu_ctrl_cpu_util
Control CPU utilization of Ascend AI processors
0%–100%
N/A
N/A
N/A
AI Processor Control CPU Frequency
ma_node_npu_ctrl_cpu_frequency_hertz
Control CPU frequency of Ascend AI processors
Hertz (Hz)
> 0
System mode (dedicated resource pool user mode)
N/A
N/A
N/A
AI Vector Core Usage
ma_container_npu_vector_core_util
AI vector core usage of Ascend AI processors
0%–100%
Suggestion
NPU RoCE network
NPU RoCE Network Uplink Rate
ma_container_npu_roce_tx_rate_bytes_per_second
Uplink rate of the NPU network module used by the container
Bytes/s
≥ 0
N/A
N/A
N/A
NPU RoCE Network Downlink Rate
ma_container_npu_roce_rx_rate_bytes_per_second
Downlink rate of the NPU network module used by the container
Bytes/s
≥ 0
N/A
N/A
N/A
Notebook service metrics
Notebook Cache Directory Size
ma_container_notebook_cache_dir_size_bytes
A high-speed local disk is attached to the /cache directory for GPU and NPU notebook instances. This metric indicates the total size of the directory.
Bytes
≥ 0
N/A
N/A
N/A
Notebook Cache Directory Utilization
ma_container_notebook_cache_dir_util
A high-speed local disk is attached to the /cache directory for GPU and NPU notebook instances. This metric indicates the utilization of the directory.
0%–100%
Raw data > 90% for two consecutive periods
Major
If the disk usage is too high, the notebook instance will be restarted.
Node-level Metrics
Table 2 Node metrics (collected only in dedicated resource pools)
Category
Name
Metric
Unit
Value Range
Alarm Threshold
Alarm Severity
Solution
CPU
Total CPU Cores
ma_node_cpu_limit_core
Total number of CPU cores that have been requested for a measured object
Cores
≥ 1
N/A
N/A
N/A
Used CPU Cores
ma_node_cpu_used_core
Cores
≥ 0
N/A
N/A
N/A
CPU Usage
ma_node_cpu_util
0%–100%
Major
CPU I/O Wait Time
ma_node_cpu_iowait_counter
Disk I/O wait time accumulated since system startup
jiffies
≥ 0
N/A
N/A
N/A
Memory
ma_node_memory_util
0%–100%
Major
ma_node_memory_total_megabytes
Total physical memory that has been applied for a measured object
MB
≥ 0
N/A
N/A
N/A
Network I/O
Downlink Rate (BPS)
ma_node_network_receive_rate_bytes_seconds
Bytes/s
≥ 0
N/A
N/A
N/A
Uplink Rate (BPS)
ma_node_network_transmit_rate_bytes_seconds
Bytes/s
≥ 0
N/A
N/A
N/A
Disk Read Rate
ma_node_disk_read_rate_kilobytes_seconds
Volume of data read from a disk per second (Only data disks used by containers are collected.)
KB/s
≥ 0
N/A
N/A
N/A
Disk Write Rate
ma_node_disk_write_rate_kilobytes_seconds
Volume of data written into a disk per second (Only data disks used by containers are collected.)
KB/s
≥ 0
N/A
N/A
N/A
Total Cache
ma_node_cache_space_capacity_megabytes
Total cache of the Kubernetes space
MB
≥ 0
N/A
N/A
N/A
Used Cache
ma_node_cache_space_used_capacity_megabytes
Used cache of the Kubernetes space
MB
≥ 0
N/A
N/A
N/A
Cache Usage
ma_node_cache_space_used_percent
Cache usage of the Kubernetes space
≥ 0
Critical
Check the disk in a timely manner to avoid affecting services. Clear invalid data on compute nodes.
Total Container Space
ma_node_container_space_capacity_megabytes
Total container space
MB
≥ 0
N/A
N/A
N/A
Used Container Space
ma_node_container_space_used_capacity_megabytes
Used container space
MB
≥ 0
N/A
N/A
N/A
Container Space Usage
ma_node_container_space_used_percent
Space usage of a container
≥ 0
Critical
Disk Information
ma_node_disk_info
Basic disk information
≥ 0
N/A
N/A
N/A
Total Reads
ma_node_disk_reads_completed_total
Total number of successful reads
≥ 0
N/A
N/A
N/A
Merged Reads
ma_node_disk_reads_merged_total
Number of merged reads
≥ 0
N/A
N/A
N/A
Bytes Read
ma_node_disk_read_bytes_total
Total number of bytes that are successfully read
Bytes
≥ 0
N/A
N/A
N/A
Read Time Spent
ma_node_disk_read_time_seconds_total
Time spent on all reads
Seconds
≥ 0
N/A
N/A
N/A
Total Writes
ma_node_disk_writes_completed_total
Total number of successful writes
≥ 0
N/A
N/A
N/A
Merged Writes
ma_node_disk_writes_merged_total
Number of merged writes
≥ 0
N/A
N/A
N/A
Written Bytes
ma_node_disk_written_bytes_total
Total number of bytes that are successfully written
Bytes
≥ 0
N/A
N/A
N/A
Write Time Spent
ma_node_disk_write_time_seconds_total
Time spent on all write operations
Seconds
≥ 0
N/A
N/A
N/A
Ongoing I/Os
ma_node_disk_io_now
Number of ongoing I/Os
≥ 0
N/A
N/A
N/A
I/O Execution Duration
ma_node_disk_io_time_seconds_total
Time spent on executing I/Os
Seconds
≥ 0
N/A
N/A
N/A
I/O Execution Weighted Time
ma_node_disk_io_time_weighted_seconds_tota
Weighted time spent on executing I/Os
Seconds
≥ 0
N/A
N/A
N/A
GPU
GPU Usage
ma_node_gpu_util
0%–100%
N/A
N/A
N/A
Total GPU Memory
ma_node_gpu_mem_total_megabytes
Total GPU memory of a measured object
MB
> 0
N/A
N/A
N/A
GPU Memory Usage
ma_node_gpu_mem_util
0%–100%
Raw data > 97% for two consecutive periods
Suggestion
Used GPU Memory
ma_node_gpu_mem_used_megabytes
MB
≥ 0
N/A
N/A
N/A
Idle GPU Memory
ma_node_gpu_mem_free_megabytes
MB
> 0
N/A
N/A
N/A
Tasks on a Shared GPU
node_gpu_share_job_count
Number of tasks running on a shared GPU
Number
≥ 0
N/A
N/A
N/A
GPU Temperature
GPU temperature
°C
Natural number
N/A
N/A
N/A
GPU Power
GPU power
Watt (W)
> 0
N/A
N/A
N/A
°C
Natural number
N/A
N/A
N/A
NPU
NPU Usage
ma_node_npu_util
NPU usage of a measured object (To be replaced by ma_node_npu_ai_core_util)
0%–100%
N/A
N/A
N/A
NPU Memory Usage
ma_node_npu_memory_util
Percentage of the used NPU memory to the total NPU memory (To be replaced by ma_node_npu_ddr_memory_util for Snt3 series, and ma_node_npu_hbm_util for Snt9 series)
0%–100%
Suggestion
Used NPU Memory
ma_node_npu_memory_used_megabytes
NPU memory used by a measured object (To be replaced by ma_node_npu_ddr_memory_usage_bytes for Snt3 series, and ma_node_npu_hbm_usage_bytes for Snt9 series)
≥ 0
MB
N/A
N/A
N/A
Total NPU Memory
ma_node_npu_memory_total_megabytes
Total NPU memory of a measured object (To be replaced by ma_node_npu_ddr_memory_bytes for Snt3 series, and ma_node_npu_hbm_bytes for Snt9 series)
> 0
MB
N/A
N/A
N/A
ma_node_npu_ai_core_error_code
N/A
N/A
N/A
ma_node_npu_ai_core_health_status
  • 1: healthy
  • 0: unhealthy
The value is 0 for two consecutive periods.
Critical
Submit a service ticket.
ma_node_npu_ai_core_power_usage_watts
Watt (W)
> 0
N/A
N/A
N/A
ma_node_npu_ai_core_temperature_celsius
°C
Natural number
N/A
N/A
N/A
AI Core Usage
0%–100%
N/A
N/A
N/A
Overall NPU Usage
ma_node_npu_general_util
0%–100%
N/A
N/A
N/A
ma_node_npu_ai_core_frequency_hertz
Hertz (Hz)
> 0
N/A
N/A
N/A
ma_node_npu_ai_core_voltage_volts
Volt (V)
Natural number
N/A
N/A
N/A
Byte
> 0
N/A
N/A
N/A
Byte
> 0
N/A
N/A
N/A
0%–100%
Suggestion
Byte
> 0
N/A
N/A
N/A
Byte
> 0
N/A
N/A
N/A
0%–100%
Suggestion
ma_node_npu_hbm_bandwidth_util
0%–100%
N/A
N/A
N/A
ma_node_npu_hbm_frequency_hertz
Hertz (Hz)
> 0
N/A
N/A
N/A
ma_node_npu_hbm_temperature_celsius
°C
Natural number
N/A
N/A
N/A
AI CPU Utilization
ma_node_npu_ai_cpu_util
0%–100%
N/A
N/A
N/A
ma_node_npu_ctrl_cpu_util
0%–100%
N/A
N/A
N/A
Hertz (Hz)
> 0
System mode (available for dedicated resource pool users)
N/A
N/A
N/A
HBM ECC Detection Switch
ma_node_npu_hbm_ecc_enable
0 indicates that ECC detection is disabled. 1 indicates that ECC detection is enabled.
  • 1: enabled
  • 0: disabled
N/A
N/A
N/A
Current HBM Single-bit Errors
ma_node_npu_hbm_single_bit_error_total
Current number of HBM single-bit errors
Number
≥ 0
N/A
N/A
N/A
Current HBM Multi-bit Errors
ma_node_npu_hbm_double_bit_error_total
Current number of HBM multi-bit errors
Number
≥ 0
N/A
N/A
N/A
Total Single-bit Errors in the HBM Life Cycle
ma_node_npu_hbm_total_single_bit_error_total
Total number of single-bit errors in the HBM life cycle
Number
≥ 0
N/A
N/A
N/A
Total Multi-bit Errors in the HBM Life Cycle
ma_node_npu_hbm_total_double_bit_error_total
Total number of multi-bit errors in the HBM life cycle
Number
≥ 0
N/A
N/A
N/A
Isolated NPU Memory Pages with HBM Single-bit Errors
ma_node_npu_hbm_single_bit_isolated_pages_total
Number of isolated NPU memory pages with HBM single-bit errors
Number
≥ 0
N/A
N/A
N/A
Isolated NPU Memory Pages with HBM Multi-bit Errors
ma_node_npu_hbm_double_bit_isolated_pages_total
Number of isolated NPU memory pages with HBM multi-bit errors Note:
If there are more than 64 pages, change the NPU.
Number
≥ 0
Raw data ≥ 64 for two consecutive periods
Critical
If there are more than 64 pages, submit a service ticket, and switch the NPU server.
ma_node_npu_vector_core_util
0%–100%
N/A
N/A
N/A
NPU RoCE network
ma_node_npu_roce_tx_rate_bytes_per_second
NPU RoCE network uplink rate
Bytes/s
≥ 0
N/A
N/A
N/A
ma_node_npu_roce_rx_rate_bytes_per_second
NPU RoCE network downlink rate
Bytes/s
≥ 0
N/A
N/A
N/A
MAC Uplink Pause Frames
ma_node_npu_roce_mac_tx_pause_packets_total
Total number of pause frame packets sent by NPU RoCE network MAC
Number
≥ 0
N/A
N/A
N/A
MAC Downlink Pause Frames
ma_node_npu_roce_mac_rx_pause_packets_total
Total number of pause frame packets received by NPU RoCE network MAC
Number
≥ 0
N/A
N/A
N/A
MAC Uplink PFC Frames
ma_node_npu_roce_mac_tx_pfc_packets_total
Total number of PFC frame packets sent by NPU RoCE network MAC
Number
≥ 0
delta(ma_node_npu_roce_mac_tx_pause_packets_total[1m]) > 0
Major
MAC Downlink PFC Frames
ma_node_npu_roce_mac_rx_pfc_packets_total
Total number of PFC frame packets received by NPU RoCE network MAC
Number
≥ 0
delta(ma_node_npu_roce_mac_rx_pause_packets_total[1m]) > 0
Major
MAC Uplink Bad Packets
ma_node_npu_roce_mac_tx_bad_packets_total
Total number of bad packets sent by NPU RoCE network MAC
Number
≥ 0
delta(ma_node_npu_roce_mac_tx_pfc_packets_total[1m]) > 0
Major
MAC Downlink Bad Packets
ma_node_npu_roce_mac_rx_bad_packets_total
Total number of bad packets received by NPU RoCE network MAC
Number
≥ 0
delta(ma_node_npu_roce_mac_rx_pfc_packets_total[1m]) > 0
Major
RoCE Uplink Bad Packets
ma_node_npu_roce_tx_err_packets_total
Number
≥ 0
delta(ma_node_npu_roce_mac_tx_bad_packets_total[1m]) > 0
Major
RoCE Downlink Bad Packets
ma_node_npu_roce_rx_err_packets_total
Number
≥ 0
delta(ma_node_npu_roce_mac_rx_bad_packets_total[1m]) > 0
Major
RoCE Uplink Packets
ma_node_npu_roce_tx_all_packets_total
Total number of packets sent by NPU RoCE
Number
≥ 0
delta(ma_node_npu_roce_tx_err_packets_total[1m]) > 0
Major
RoCE Downlink Packets
ma_node_npu_roce_rx_all_packets_total
Total number of packets received by NPU RoCE
Number
≥ 0
delta(ma_node_npu_roce_rx_err_packets_total[1m]) > 0
Major
NPU optical module (This metric is available for Snt9B/C air-cooled networking.)
Optical Module Temperature
ma_node_npu_optical_temperature
Optical module temperature
°C
≥ 0
N/A
N/A
N/A
Optical Module Power Voltage
ma_node_npu_optical_vcc
Power voltage of the optical module
Millivolt (mV)
≥ 0
N/A
N/A
N/A
Optical Module Transmit Power 0
ma_node_npu_optical_tx_power0
Transmit power 0 of the optical module
Milliwatt (mW)
≥ 0
N/A
N/A
N/A
Optical Module Transmit Power 1
ma_node_npu_optical_tx_power1
Transmit power 1 of the optical module
Milliwatt (mW)
≥ 0
N/A
N/A
N/A
Optical Module Transmit Power 2
ma_node_npu_optical_tx_power2
Transmit power 2 of the optical module
Milliwatt (mW)
≥ 0
N/A
N/A
N/A
Optical Module Transmit Power 3
ma_node_npu_optical_tx_power3
Transmit power 3 of the optical module
Milliwatt (mW)
≥ 0
N/A
N/A
N/A
Optical Module Receive Power 0
ma_node_npu_optical_rx_power0
Receive power 0 of the optical module
Milliwatt (mW)
≥ 0
N/A
N/A
N/A
Optical Module Receive Power 1
ma_node_npu_optical_rx_power1
Receive power 1 of the optical module
Milliwatt (mW)
≥ 0
N/A
N/A
N/A
Optical Module Receive Power 2
ma_node_npu_optical_rx_power2
Receive power 2 of the optical module
Milliwatt (mW)
≥ 0
N/A
N/A
N/A
Optical Module Receive Power 3
ma_node_npu_optical_rx_power3
Receive power 3 of the optical module
Milliwatt (mW)
≥ 0
N/A
N/A
N/A
InfiniBand or RoCE network
Total Amount of Data Received by a NIC
ma_node_infiniband_port_received_data_bytes_total
The total number of data octets, divided by 4, (counting in double words, 32 bits), received on all VLs from the port.
≥ 0
N/A
N/A
N/A
Total Amount of Data Sent by a NIC
ma_node_infiniband_port_transmitted_data_bytes_total
The total number of data octets, divided by 4, (counting in double words, 32 bits), transmitted on all VLs from the port.
≥ 0
N/A
N/A
N/A
NFS mounting status
NFS Getattr Congestion Time
ma_node_mountstats_getattr_backlog_wait
Getattr is an NFS operation that retrieves the attributes of a file or directory, such as size, permissions, owner, etc. Backlog wait is the time that the NFS requests have to wait in the backlog queue before being sent to the NFS server. It indicates the congestion on the NFS client side. A high backlog wait can cause poor NFS performance and slow system response times.
ms
≥ 0
N/A
N/A
N/A
NFS Getattr Round Trip Time
ma_node_mountstats_getattr_rtt
RTT stands for Round Trip Time and it is the time from when the kernel RPC client sends the RPC request to the time it receives the reply34. RTT includes network transit time and server execution time. RTT is a good measurement for NFS latency. A high RTT can indicate network or server issues.
ms
≥ 0
N/A
N/A
N/A
NFS Access Congestion Time
ma_node_mountstats_access_backlog_wait
Access is an NFS operation that checks the access permissions of a file or directory for a given user. Backlog wait is the time that the NFS requests have to wait in the backlog queue before being sent to the NFS server. It indicates the congestion on the NFS client side. A high backlog wait can cause poor NFS performance and slow system response times.
ms
≥ 0
N/A
N/A
N/A
NFS Access Round Trip Time
ma_node_mountstats_access_rtt
Access is an NFS operation that checks the access permissions of a file or directory for a given user. RTT stands for Round Trip Time and it is the time from when the kernel RPC client sends the RPC request to the time it receives the reply34. RTT includes network transit time and server execution time. RTT is a good measurement for NFS latency. A high RTT can indicate network or server issues.
ms
≥ 0
N/A
N/A
N/A
NFS Lookup Congestion Time
ma_node_mountstats_lookup_backlog_wait
Lookup is an NFS operation that resolves a file name in a directory to a file handle. Backlog wait is the time that the NFS requests have to wait in the backlog queue before being sent to the NFS server. It indicates the congestion on the NFS client side. A high backlog wait can cause poor NFS performance and slow system response times.
ms
≥ 0
N/A
N/A
N/A
NFS Lookup Round Trip Time
ma_node_mountstats_lookup_rtt
Lookup is an NFS operation that resolves a file name in a directory to a file handle. RTT stands for Round Trip Time and it is the time from when the kernel RPC client sends the RPC request to the time it receives the reply34. RTT includes network transit time and server execution time. RTT is a good measurement for NFS latency. A high RTT can indicate network or server issues.
ms
≥ 0
N/A
N/A
N/A
NFS Read Congestion Time
ma_node_mountstats_read_backlog_wait
Read is an NFS operation that reads data from a file. Backlog wait is the time that the NFS requests have to wait in the backlog queue before being sent to the NFS server. It indicates the congestion on the NFS client side. A high backlog wait can cause poor NFS performance and slow system response times.
ms
≥ 0
N/A
N/A
N/A
NFS Read Round Trip Time
ma_node_mountstats_read_rtt
Read is an NFS operation that reads data from a file. RTT stands for Round Trip Time and it is the time from when the kernel RPC client sends the RPC request to the time it receives the reply34. RTT includes network transit time and server execution time. RTT is a good measurement for NFS latency. A high RTT can indicate network or server issues.
ms
≥ 0
N/A
N/A
N/A
NFS Write Congestion Time
ma_node_mountstats_write_backlog_wait
Write is an NFS operation that writes data to a file. Backlog wait is the time that the NFS requests have to wait in the backlog queue before being sent to the NFS server. It indicates the congestion on the NFS client side. A high backlog wait can cause poor NFS performance and slow system response times.
ms
≥ 0
N/A
N/A
N/A
NFS Write Round Trip Time
ma_node_mountstats_write_rtt
Write is an NFS operation that writes data to a file. RTT stands for Round Trip Time and it is the time from when the kernel RPC client sends the RPC request to the time it receives the reply34. RTT includes network transit time and server execution time. RTT is a good measurement for NFS latency. A high RTT can indicate network or server issues.
ms
≥ 0
N/A
N/A
N/A
Networking Metrics
Table 3 Diagnosis (InfiniBand, collected only in dedicated resource pools)
Category
Name
Metric
Unit
Value Range
PortXmitData
infiniband_port_xmit_data_total
Total count
Natural number
PortRcvData
infiniband_port_rcv_data_total
Total count
Natural number
SymbolErrorCounter
infiniband_symbol_error_counter_total
Total number of minor link errors detected on one or more physical lanes.
Total count
Natural number
LinkErrorRecoveryCounter
infiniband_link_error_recovery_counter_total
Total number of times the Port Training state machine has successfully completed the link error recovery process.
Total count
Natural number
PortRcvErrors
infiniband_port_rcv_errors_total
Total number of packets containing errors that were received on the port including:
Local physical errors (ICRC, VCRC, LPCRC, and all physical errors that cause entry into the BAD PACKET or BAD PACKET DISCARD states of the packet receiver state machine)
Malformed data packet errors (LVer, length, VL)
Malformed link packet errors (operand, length, VL)
Packets discarded due to buffer overrun (overflow)
Total count
Natural number
LocalLinkIntegrityErrors
infiniband_local_link_integrity_errors_total
This counter indicates the number of retries initiated by a link transfer layer receiver.
Total count
Natural number
PortRcvRemotePhysicalErrors
infiniband_port_rcv_remote_physical_errors_total
Total number of packets marked with the EBP delimiter received on the port.
Total count
Natural number
PortRcvSwitchRelayErrors
infiniband_port_rcv_switch_relay_errors_total
Total number of packets received on the port that were discarded when they could not be forwarded by the switch relay for the following reasons:
DLID mapping
VL mapping
Looping (output port = input port)
Total count
Natural number
PortXmitWait
infiniband_port_transmit_wait_total
The number of ticks during which the port had data to transmit but no data was sent during the entire tick (either because of insufficient credits or because of lack of arbitration).
Total count
Natural number
PortXmitDiscards
infiniband_port_xmit_discards_total
Total number of outbound packets discarded by the port because the port is down or congested.
Total count
Natural number
Label Metrics
Table 4 Metric labels
Classification
Label
Container metrics
modelarts_service
Service to which a container belongs, which can be notebook, train, or infer
instance_name
Name of the pod to which the container belongs
service_id
Instance or job ID displayed on the page, for example, cf55829e-9bd3-48fa-8071-7ae870dae93a for a development environment
9f322d5a-b1d2-4370-94df-5a87de27d36e for a training job
node_ip
IP address of the node to which the container belongs
container_id
Container ID
cid
Cluster ID
container_name
Container name
project_id
Project ID of the account to which the user belongs
user_id
User ID of the account to which the user who submits the job belongs
pool_id
ID of a resource pool corresponding to a physical dedicated resource pool
pool_name
Name of a resource pool corresponding to a physical dedicated resource pool
logical_pool_id
ID of a logical subpool
logical_pool_name
Name of a logical subpool
gpu_uuid
UUID of the GPU used by the container
gpu_index
Index of the GPU used by the container
gpu_type
Type of the GPU used by the container
account_name
Account name of the creator of a training, inference, or development environment task
user_name
Username of the creator of a training, inference, or development environment task
task_creation_time
Time when a training, inference, or development environment task is created
task_name
Name of a training, inference, or development environment task
task_spec_code
Specifications of a training, inference, or development environment task
cluster_name
CCE cluster name
Node metrics
cid
ID of the CCE cluster to which the node belongs
node_ip
host_name
Hostname of a node
pool_id
project_id
Project ID of the user in a physical dedicated resource pool
gpu_uuid
UUID of a node GPU
gpu_index
Index of a node GPU
gpu_type
Type of a node GPU
device_name
Device name of an InfiniBand or RoCE network NIC
port
Port number of the InfiniBand NIC
physical_state
Status of each port on the InfiniBand NIC
firmware_version
Firmware version of the IB NIC
filesystem
NFS-mounted file system
mount_point
NFS mount point
Diagnos
cid
ID of the CCE cluster to which the node where the GPU resides belongs
node_ip
IP address of the node where the GPU resides
pool_id
project_id
gpu_uuid
GPU UUID
gpu_index
Index of a node GPU
gpu_type
Type of a node GPU
device_name
Name of a network device or disk device
port
physical_state
firmware_version
Firmware version of the InfiniBand NIC
