Preparing Predictive Analysis Data
Updated on 2024-12-31 GMT+08:00
Before using ModelArts to build a predictive analytics model, upload data to OBS. The OBS bucket and ModelArts must be in the same region. For example, if the OBS bucket is in the CN North-Beijing4 region, ensure that the ModelArts management console is also in the CN North-Beijing4 region. Otherwise, data cannot be obtained.
Requirements on Datasets
The data set used in the predictive analytics project must be a table dataset in .csv format. For details about the table dataset, see Table dataset.
To convert the data from .xlsx to .csv, perform the following operations:
Save the original table data in .xlsx. Choose File > Save As, select a local address, set Save as type: to CSV (Comma delimited), and click Save. Then, click OK in the displayed dialog box.
Requirements on the training data:
  • The number of columns in the training data must be the same, and there has to be at least 100 data records (a feature with different values is considered as different data records).
  • The training columns cannot contain timestamp data (such as yy-mm-dd or yyyy-mm-dd).
  • If a column has only one value, the column is considered invalid. Ensure that there are at least two values in the label column and no data is missing.
    The label column is the training target specified in a training task. It is the output (prediction item) for the model trained using the dataset.
  • In addition to the label column, the dataset must contain at least two valid feature columns. Ensure that there are at least two values in each feature column and that the percentage of missing data must be lower than 10%.
  • Due to the limitation of the feature filtering algorithm, place the predictive data column at the last. Otherwise, the training may fail.
Example of a table dataset:
The following table takes the bank deposit predictive dataset as an example. Data sources include age, occupation, marital status, cultural level, and whether there is a personal mortgage or personal loan.
Table 1 Fields and meanings of data sources
Field
Meaning
Type
attr_1
Age
Int
Age of the customer
attr_2
Occupation
String
Occupation of the customer
attr_3
Marital status
String
Marital status of the customer
attr_4
Education status
String
Education status of the customer
attr_5
Real estate
String
Housing situation of the customer
attr_6
Loan
String
Loan of the customer
attr_7
Deposit
String
Deposit of the customer
Table 2 Sample data of the dataset
attr_1
attr_2
attr_3
attr_4
attr_5
attr_6
attr_7
31
blue-collar
married
secondary
yes
no
no
41
management
married
tertiary
yes
yes
no
38
technician
single
secondary
yes
no
no
39
technician
single
secondary
yes
no
yes
39
blue-collar
married
secondary
yes
no
no
39
services
single
unknown
yes
no
no
Uploading Data to OBS
In this section, the OBS console is used to upload data.
Upload files to OBS according to the following specifications:
The OBS path of the predictive analytics projects must comply with the following rules:
  • The OBS path of the input data must redirect to the data files. The data files must be stored in a folder in an OBS bucket rather than the root directory of the OBS bucket, for example, /obs-xxx/data/input.csv.
  • There must be at least 100 lines of valid data in .csv. There cannot be more than 200 columns of data and the total data size must be smaller than 100 MB.
Procedure for uploading data to OBS:
Perform the following operations to import data to the dataset for model training and building.
  1. Log in to the OBS console and create a bucket in the same region as ModelArts. If an available bucket exists, ensure that the OBS bucket and ModelArts are in the same region.
  2. Upload the local data to the OBS bucket. If you have a large amount of data, use OBS Browser+ to upload data or folders. The uploaded data must meet the dataset requirements of the ExeML project.
Upload data from unencrypted buckets. Otherwise, training will fail because data cannot be decrypted.
Creating a Dataset
After data is prepared, create a dataset of the type supported by the project. For details, see Creating a Dataset.
How do I process Schema information when creating a table dataset using data selected from OBS?
Schema information includes the names and types of table columns, which must be the same as those of the imported data.
  • If the original table contains a table header, enable Contain Table Header. The first row's data of the file will be used as column names. You do not need to modify the Schema information.
  • If the original table does not contain a table header, disable Contain Table Header. After data is selected from OBS, the first row's data of the table will be used as the column names by default. Change the column names in Schema information to attr_1, attr_2, ..., attr_n. attr_n is the prediction column placed at last.
