Example: Creating a DDP Distributed Training Job (PyTorch + GPU)
PyTorch's DDP enables efficient distributed training. This section describes how to start DDP training with sample code provided.
- Use PyTorch preset images and run the mp.spawn command.
- Use custom images.
- Run the torch.distributed.launch command.
- Run the torch.distributed.run command.
These methods offer adaptable solutions tailored to specific needs and setups.
After reviewing this section, choose the right boot mode for your situation to start using PyTorch distributed training efficiently.
Creating a Training Job
- Method 1: Use the preset PyTorch framework and run the mp.spawn command to start a training job.
For details about parameters for creating a training job, see Table 1.
Table 1 Creating a training job (preset image) Parameter
Algorithm Type
Select Custom algorithm.
Boot Mode
Select Preset image then PyTorch. Select a version as needed.
Code Directory
Select the training code path from your OBS bucket, for example, obs://test-modelarts/code/.
Boot File
Select the Python boot script of the training job in the code directory, for example, obs://test-modelarts/code/main.py.
Hyperparameter
To use a single-node multi-PU flavor, set the hyperparameters world_size and rank.
If you choose a flavor with multiple instances, these hyperparameters are automatically set by ModelArts.
- Method 2: Use a custom image and run the torch.distributed.launch command to start a training job.
For details about parameters for creating a training job, see Table 2.
Table 2 Creating a training job (custom image + torch.distributed.launch) Parameter
Algorithm Type
Boot Mode
Select Custom image.
Select a PyTorch image for training.
Code Directory
Boot Command
Enter the Python boot command of the image, for example:
bash ${MA_JOB_DIR}/code/torchlaunch.sh
- Method 3: Use a custom image and run the torch.distributed.run command to start a training job.
For details about parameters for creating a training job, see Table 3.
Table 3 Creating a training job (custom image + torch.distributed.run) Parameter
Algorithm Type
Boot Mode
Code Directory
Boot Command
bash ${MA_JOB_DIR}/code/torchrun.sh
Code Example
Upload the following files to an OBS bucket:
code # Root directory of the code └─torch_ddp.py # Code file for PyTorch DDP training └─main.py # Boot file for starting training using the PyTorch preset image and the mp.spawn command └─torchlaunch.sh # Boot file for starting training using the custom image and the torch.distributed.launch command └─torchrun.sh # Boot file for starting training using the custom image and the torch.distributed.run command
torch_ddp.py
import os import torch import torch.distributed as dist import torch.nn as nn import torch.optim as optim from torch.nn.parallel import DistributedDataParallel as DDP # Start training by running mp.spawn. def init_from_arg(local_rank, base_rank, world_size, init_method): rank = base_rank + local_rank dist.init_process_group("nccl", rank=rank, init_method=init_method, world_size=world_size) ddp_train(local_rank) # Start training by running torch.distributed.launch or torch.distributed.run. def init_from_env(): dist.init_process_group(backend='nccl', init_method='env://') local_rank=int(os.environ["LOCAL_RANK"]) ddp_train(local_rank) def cleanup(): dist.destroy_process_group() class ToyModel(nn.Module): def __init__(self): super(ToyModel, self).__init__() self.net1 = nn.Linear(10, 10) self.relu = nn.ReLU() self.net2 = nn.Linear(10, 5) def forward(self, x): return self.net2(self.relu(self.net1(x))) def ddp_train(device_id): # create model and move it to GPU with id rank model = ToyModel().to(device_id) ddp_model = DDP(model, device_ids=[device_id]) loss_fn = nn.MSELoss() optimizer = optim.SGD(ddp_model.parameters(), lr=0.001) optimizer.zero_grad() outputs = ddp_model(torch.randn(20, 10)) labels = torch.randn(20, 5).to(device_id) loss_fn(outputs, labels).backward() optimizer.step() cleanup() if __name__ == "__main__": init_from_env()
main.py
import argparse import torch import torch.multiprocessing as mp parser = argparse.ArgumentParser(description='ddp demo args') parser.add_argument('--world_size', type=int, required=True) parser.add_argument('--rank', type=int, required=True) parser.add_argument('--init_method', type=str, required=True) args, unknown = parser.parse_known_args() if __name__ == "__main__": n_gpus = torch.cuda.device_count() world_size = n_gpus * args.world_size base_rank = n_gpus * args.rank # Call the start function in the DDP sample code. from torch_ddp import init_from_arg mp.spawn(init_from_arg, args=(base_rank, world_size, args.init_method), nprocs=n_gpus, join=True)
#!/bin/bash # Default system environment variables. Do not modify them. MASTER_HOST="$VC_WORKER_HOSTS" MASTER_ADDR="${VC_WORKER_HOSTS%%,*}" MASTER_PORT="6060" JOB_ID="1234" NNODES="$MA_NUM_HOSTS" NODE_RANK="$VC_TASK_INDEX" NGPUS_PER_NODE="$MA_NUM_GPUS" # Custom environment variables to specify the Python script and parameters. PYTHON_SCRIPT=${MA_JOB_DIR}/code/torch_ddp.py PYTHON_ARGS="" CMD="python -m torch.distributed.launch \ --nnodes=$NNODES \ --node_rank=$NODE_RANK \ --nproc_per_node=$NGPUS_PER_NODE \ --master_addr $MASTER_ADDR \ --master_port=$MASTER_PORT \ --use_env \ $PYTHON_SCRIPT \ $PYTHON_ARGS " echo $CMD $CMD
torchrun.sh
In PyTorch 2.1, you must set rdzv_backend to static: --rdzv_backend=static.
#!/bin/bash # Default system environment variables. Do not modify them. MASTER_HOST="$VC_WORKER_HOSTS" MASTER_ADDR="${VC_WORKER_HOSTS%%,*}" MASTER_PORT="6060" JOB_ID="1234" NNODES="$MA_NUM_HOSTS" NODE_RANK="$VC_TASK_INDEX" NGPUS_PER_NODE="$MA_NUM_GPUS" # Custom environment variables to specify the Python script and parameters. PYTHON_SCRIPT=${MA_JOB_DIR}/code/torch_ddp.py PYTHON_ARGS="" if [[ $NODE_RANK == 0 ]]; then EXT_ARGS="--rdzv_conf=is_host=1" else EXT_ARGS="" fi CMD="python -m torch.distributed.run \ --nnodes=$NNODES \ --node_rank=$NODE_RANK \ $EXT_ARGS \ --nproc_per_node=$NGPUS_PER_NODE \ --rdzv_id=$JOB_ID \ --rdzv_backend=c10d \ --rdzv_endpoint=$MASTER_ADDR:$MASTER_PORT \ $PYTHON_SCRIPT \ $PYTHON_ARGS " echo $CMD $CMD
