Accessing a Real-Time Service Through a VPC High-Speed Channel
Updated on 2024-12-26 GMT+08:00
Context
When accessing a real-time service, you may require:
  • High throughput and low latency
  • TCP or RPC requests
To meet these requirements, ModelArts enables high-speed access through VPC peering.
In high-speed access through VPC peering, your service requests are directly sent to instances through VPC peering but not through the inference platform. This accelerates service access.
The following features that are available through the inference platform will be unavailable if you use high-speed access:
  • Authentication
  • Traffic distribution by configuration
  • Load balancing
  • Alarm, monitoring, and statistics
Figure 1 High-speed access through VPC peering
When you call an API to access a real-time service, the size of the prediction request body and the prediction time are subject to the following limitations:
  • The size of a request body cannot exceed 12 MB. Otherwise, the request will fail.
  • Due to the limitation of API Gateway, the prediction duration of each request does not exceed 40 seconds.
Preparations
Deploy a real-time service in a dedicated resource pool and ensure the service is running.
NOTICE:
  • Only the services deployed in a dedicated resource pool support high-speed access through VPC peering.
  • High-speed access through VPC peering is available only for real-time services.
  • Due to traffic control, there is a limit on how often you can get the IP address and port number of a real-time service. The number of calls of each tenant account cannot exceed 2000 per minute, and that of each IAM user account cannot exceed 20 per minute.
  • High-speed access through VPC peering is available only for the services deployed using the AI applications imported from custom images.
To enable high-speed access to a real-time service through VPC peering, perform the following operations:
  1. Interconnect the dedicated resource pool to the VPC.
  2. Create an ECS in the VPC.
  3. Obtain the IP address and port number of the real-time service.
  4. Access the service through the IP address and port number.
    Log in to the ModelArts console, choose AI Dedicated Resource Pools > Elastic Clusters, locate the dedicated resource pool where the service is deployed, and click its name/ID to go to the resource pool details page. Obtain the network configuration. Switch back to the dedicated resource pool list, click the Network tab, locate the network associated with the dedicated resource pool, and interconnect it with the VPC. After the VPC is accessed, the VPC will be displayed on the network list and resource pool details pages. Click the VPC to go to the details page.
    Figure 2 Obtaining the network configuration
    Figure 3 Interconnecting the VPC
    Log in to the ECS management console and click Buy ECS in the upper right corner. On the Buy ECS page, configure basic settings and click Next: Configure Network. On the Configure Network page, select the VPC connected in 1, configure other parameters, confirm the settings, and click Submit. When the ECS status changes to Running, the ECS has been created. Click its name/ID to go to the server details page and view the VPC configuration.
    Figure 4 Selecting a VPC when purchasing an ECS
    Figure 5 Viewing VPC information
    GUI software, for example, Postman can be used to obtain the IP address and port number. Alternatively, log in to the ECS, create a Python environment, and execute code to obtain the service IP address and port number.
    API:
    GET /v1/{project_id}/services/{service_id}/predict/endpoints?type=host_endpoints
    • Method 1: Obtain the IP address and port number using GUI software.
      Figure 6 Example response
    • Method 2: Obtain the IP address and port number using Python.
      The following parameters in the Python code below need to be modified:
      • project_id: your project ID. To obtain it, see Obtaining a Project ID and Name.
      • service_id: service ID, which can be viewed on the service details page.
      • REGION_ENDPOINT: service endpoint. To obtain it, see Endpoint.
      def get_app_info(project_id, service_id):
          list_host_endpoints_url = "{}/v1/{}/services/{}/predict/endpoints?type=host_endpoints"
          url = list_host_endpoints_url.format(REGION_ENDPOINT, project_id, service_id)
          headers = {'X-Auth-Token': X_Auth_Token}
          response = requests.get(url, headers=headers)
          print(response.content)
    Log in to the ECS and access the real-time service either by running Linux commands or by creating a Python environment and executing Python code. Obtain the values of schema, ip, and port from 3.
    • Run the following command to access the real-time service:
      curl --location --request POST 'http://192.168.205.58:31997' \
      --header 'Content-Type:  application/json' \
      --data-raw '{"a":"a"}'
      Figure 7 Accessing a real-time service
    • Create a Python environment and execute Python code to access the real-time service.
      def vpc_infer(schema, ip, port, body):
          infer_url = "{}://{}:{}"
          url = infer_url.format(schema, ip, port)
          response = requests.post(url, data=body)
    High-speed access does not support load balancing. You need to customize load balancing policies when you deploy multiple instances.
