On this page
Show all
Deploying and Using Real-Time Inference
Updated on 2024-12-26 GMT+08:00
After creating a model, you can deploy it as a real-time service. If a real-time service is in the Running status, it has been deployed. This service provides a standard, callable RESTful API. When accessing a real-time service, you can choose the authentication method, access channel, and transmission protocol that best suit your needs. These three elements make up your access requests and can be mixed and matched without any interference. For example, you can use different authentication methods for different access channels and transmission protocols.
Figure 1 Authentication method, access channel, and transmission protocol
ModelArts supports the following authentication methods for accessing real-time services (HTTPS requests are used as examples):
  • Token-based authentication: The validity period of a token is 24 hours. When using a token for authentication, cache it to prevent frequent calls.
  • AK/SK-based authentication: AK/SK is used to sign requests and the signature is then added to the request for authentication. AK/SK-based authentication supports API requests with a body not larger than 12 MB. For API requests with a larger body, token-based authentication is recommended.
  • App authentication: Add a parameter to the request header to complete the authentication. The authentication is simple and permanently valid.
ModelArts allows you to call APIs to access real-time services in the following ways (HTTPS requests are used as examples):
Real-time service APIs are accessed using HTTPS by default. Additionally, the following transmission protocols are also supported:
  • Accessing a Real-Time Service Using WebSocket: WebSocket simplifies data exchange between the client and server and allows the server to proactively push data to the client. In the WebSocket API, if the initial handshake between the client and the server is successful, a persistent connection will be established between them and data can be transferred bidirectionally.
  • Accessing a Real-Time Service Using Server-Sent Events: Server-Sent Events (SSE) primarily facilitates unidirectional real-time communication from the server to the client, such as streaming ChatGPT responses. In contrast to WebSockets, which provide bidirectional real-time communication, SSE is designed to be more lightweight and simpler to implement.
