Modifying a Real-Time Service
Updated on 2024-12-26 GMT+08:00
For a deployed service, you can modify its basic information to match service changes and change the model version to upgrade it.
You can modify the basic information about a service in either of the following ways:
Method 1: Modify the Service Information on the Service Management Page
Method 2: Modify the Service Information on the Service Details Page
The service has been deployed. The service in the Deploying state cannot be upgraded by modifying the service information.
  • Improper upgrade operations will interrupt services during the upgrade.
  • ModelArts supports hitless rolling upgrade of real-time services in some scenarios. Prepare for and fully verify the upgrade.
    Table 1 Scenarios for hitless rolling upgrade
    Meta Model Source
    Using a Public Resource Pool
    Using a Dedicated Resource Pool
    Training job
    Not supported
    Not supported
    Container image
    Not supported
    Supported. The custom image for creating a model must meet Specifications for Custom Images.
    OBS
    Not supported
    Not supported
  1. Log in to the ModelArts console and choose Model Deployment from the navigation pane. Go to the service management page of the target service.
  2. In the service list, click Modify in the Operation column of the target service, modify basic service information, and submit the modification task as prompted.
    When some parameters are modified, the system automatically restarts the service for the modification to take effect. When you submit a service modification task, if a restart is required, a dialog box will be displayed.
    For details about the real-time service parameters, see Deploying a Model as a Real-Time Service. To modify a real-time service, you also need to set Max. Invalid Instances to set the maximum number of nodes that can be concurrently upgraded, during which time these nodes are invalid.
  2. Click the name of the target service to access its details page.
  3. Click Modify in the upper right corner of the page, modify the service details, and submit the modification task as prompted.
