Accessing a Real-Time Service Through AK/SK-based Authentication
Updated on 2024-12-31 GMT+08:00
If a real-time service is in the Running state, it has been deployed. This service provides a standard, callable RESTful API. You can call the API using AK/SK-based authentication.
When AK/SK-based authentication is used, you can use the APIG SDK or ModelArts SDK to access the real-time service. For details, see Overview of Session Authentication. This section describes how to use the APIG SDK to access a real-time service. The process is as follows:
  1. Obtaining an AK/SK Pair
  2. Obtaining Information About a Real-Time Service
  3. Send an inference request.
  1. AK/SK-based authentication supports API requests with a body not larger than 12 MB. For API requests with a larger body, use token-based authentication.
  2. The local time on the client must be synchronized with the clock server to avoid a large offset in the value of the X-Sdk-Date request header. API Gateway checks the time format and compares the time with the time when API Gateway receives the request. If the time difference exceeds 15 minutes, API Gateway will reject the request.
When you call an API to access a real-time service, the size of the prediction request body and the prediction time are subject to the following limitations:
  • The size of a request body cannot exceed 12 MB. Otherwise, the request will fail.
  • Due to the limitation of API Gateway, the prediction duration of each request does not exceed 40 seconds.
If an AK/SK pair is already available, skip this step. Find the downloaded AK/SK file, which is usually named credentials.csv.
The file contains the username, AK, and SK.
Figure 1 credential.csv
To generate an AK/SK pair, follow these steps:
  1. Sign up and log in to the console.
  2. Click the username and choose My Credentials from the drop-down list.
  3. On the My Credentials page, choose Access Keys in the navigation pane.
  4. Click Create Access Key.
  5. Complete the identity authentication, download the access key, and keep it secure.
To call an API, you will need the URL and input parameters of the real-time service. Follow these steps to obtain this information:
  1. Log in to the ModelArts console. In the navigation pane, choose Model Deployment > Real-Time Services.
  2. Click the name of the target service to access its details page.
  3. Obtain the URL and input parameters of the service.
    The API URL is the service URL. If apis defines a path in the model configuration file, append the user-defined path to the URL, for example, {URL of the real-time service}/predictions/poetry.
    Figure 2 Obtaining the API URL and file prediction input parameters of a real-time service
Method 1: Use Python to Send an Inference Request
  1. Download the Python SDK and configure it in the development tool. For details, see Integrating the Python SDK for API request signing.
  2. Create a request body for inference.
    • File input
      # coding=utf-8
      import requests
      import os
      from apig_sdk import signer
      if __name__ == '__main__':
          # Config url, ak, sk and file path.
          url = "URL of the real-time service"
          # Hardcoded or plaintext AK/SK is risky. For security, encrypt your AK/SK and store them in the configuration file or environment variables.
          # In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, set environment variables HUAWEICLOUD_SDK_AK and HUAWEICLOUD_SDK_SK.
          ak = os.environ["HUAWEICLOUD_SDK_AK"]
          sk = os.environ["HUAWEICLOUD_SDK_SK"]
          file_path = "Local path to the inference file"
          # Create request, set method, url, headers and body.
          method = 'POST'
          headers = {"x-sdk-content-sha256": "UNSIGNED-PAYLOAD"}
          request = signer.HttpRequest(method, url, headers)
          # Create sign, set the AK/SK to sign and authenticate the request.
          sig = signer.Signer()
          sig.Key = ak
          sig.Secret = sk
          sig.Sign(request)
          # Send request
          files = {'images': open(file_path, 'rb')}
          resp = requests.request(request.method, request.scheme + "://" + request.host + request.uri, headers=request.headers, files=files)
          # Print result
          print(resp.status_code)
          print(resp.text)
      file_path is the local path to the inference file. The path can be an absolute path (for example, D:/test.png for Windows and /opt/data/test.png for Linux) or a relative path (for example, ./test.png).
      Request body format of files: files = {"Request parameter": ("Load path", File content, "File type")}. For details about parameters of files, see Table 1.
      Table 1 Parameters of files
      Mandatory
      Request parameter
      Yes
      Parameter name of the real-time service.
      File path
      No
      Path for storing the file.
      File content
      Yes
      Content of the file to be uploaded.
      File type
      No
      Type of the file to be uploaded, which can be one of the following options:
      • txt: text/plain
      • jpg/jpeg: image/jpeg
      • png: image/png
    • Text input (JSON)
      The following is an example request body for reading the local inference file and performing Base64 encoding:
      # coding=utf-8
      import base64
      import json
      import os
      import requests
          with open(file_path, "rb") as file:
              base64_data = base64.b64encode(file.read()).decode("utf-8")
          method = 'POST'
          headers = {
              'Content-Type': 'application/json'
          body = {
              'image': base64_data
          request = signer.HttpRequest(method, url, headers, json.dumps(body))
          sig.Key = ak
          sig.Secret = sk
          sig.Sign(request)
          # Send request
          resp = requests.request(request.method, request.scheme + "://" + request.host + request.uri, headers=request.headers, data=request.body)
          # Print result
          print(resp.text)
      The body name is determined by the input parameter of the real-time service. The parameter name must be the same as that of the input parameter of the string type. image is used as an example. The value of base64_data in body is of the string type.
Method 2: Use Java to Send an Inference Request
  1. Download the Java SDK and configure it in the development tool.
  2. Create a Java request body for inference.
    In the APIG Java SDK, request.setBody() can only be a string. Therefore, only text inference requests are supported. If a file is input, convert the file into text using Base64.
    • File input
      The following is an example request body (JSON) for reading the local inference file and performing Base64 encoding.
      package com.apig.sdk.demo;
      import com.cloud.apigateway.sdk.utils.Client;
      import com.cloud.apigateway.sdk.utils.Request;
      import org.apache.commons.codec.binary.Base64;
      import org.apache.http.HttpHeaders;
      import org.apache.http.client.methods.CloseableHttpResponse;
      import org.apache.http.client.methods.HttpPost;
      import org.apache.http.client.methods.HttpRequestBase;
      import org.apache.http.impl.client.HttpClients;
      import org.apache.http.util.EntityUtils;
      import java.io.FileInputStream;
      import java.io.IOException;
      import java.io.InputStream;
      public class MyAkSkTest2 {
              String url = "URL of the real-time service";
             // Hard-coded or plaintext AK/SK is risky. For security, encrypt your AK/SK and store them in the configuration file or environment variables.
             // In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, set environment variables HUAWEICLOUD_SDK_AK and HUAWEICLOUD_SDK_SK.
              String ak = System.getenv("HUAWEICLOUD_SDK_AK");
             String sk = System.getenv("HUAWEICLOUD_SDK_SK");
              String filePath = "Local path to the inference file";
              try {
                  // Create request
                  Request request = new Request();
                  // Set the AK/SK to sign and authenticate the request.
                  request.setKey(ak);
                  request.setSecret(sk);
                  // Specify a request method, such as GET, PUT, POST, DELETE, HEAD, and PATCH.
                  request.setMethod(HttpPost.METHOD_NAME);
                  // Add header parameters
                  request.addHeader(HttpHeaders.CONTENT_TYPE, "application/json");
                  // Set a request URL in the format of https://{Endpoint}/{URI}.
                  request.setUrl(url);
                  // build your json body
                  String body = "{\"image\":\"" + getBase64FromFile(filePath) + "\"}";
                  // Special characters, such as the double quotation mark ("), contained in the body must be escaped.
                  request.setBody(body);
                  // Sign the request.
                  HttpRequestBase signedRequest = Client.sign(request);
                  // Send request.
                  CloseableHttpResponse response = HttpClients.createDefault().execute(signedRequest);
                  // Print result
                  System.out.println(response.getStatusLine().getStatusCode());
                  System.out.println(EntityUtils.toString(response.getEntity()));
              } catch (Exception e) {
                  e.printStackTrace();
           * Convert the file into a byte array and Base64 encode it
           * @return
          private static String getBase64FromFile(String filePath) {
              // Convert the file into a byte array
              InputStream in = null;
              byte[] data = null;
              try {
                  in = new FileInputStream(filePath);
                  data = new byte[in.available()];
                  in.read(data);
                  in.close();
              } catch (IOException e) {
              // Base64 encode
              return new String(Base64.encodeBase64(data));
      CAUTION:
      If using Base64 encoding, you need to add a decoding step to your model inference code to handle the request body.
    • Text input (JSON)
      // Package name of the demo.
      public class MyAkSkTest {
              try {
                  // Create request
                  request.setKey(ak);
                  String body = "{}";
                  // Send request.
                  // Print result
      body is determined by the text format. JSON is used as an example.
