Accessing a Real-Time Service Through Token-based Authentication
Updated on 2024-12-26 GMT+08:00
If a real-time service is in the Running state, it has been deployed successfully. This service provides a standard RESTful API for users to call. Before integrating the API to the production environment, commission the API. You can use the following methods to send an inference request to the real-time service:
When you call an API to access a real-time service, the size of the prediction request body and the prediction time are subject to the following limitations:
  • The size of a request body cannot exceed 12 MB. Otherwise, the request will fail.
  • Due to the limitation of API Gateway, the prediction duration of each request does not exceed 40 seconds.
You have obtained a user token, local path to the inference file, URL of the real-time service, and input parameters of the real-time service.
  • For details about how to obtain a user token, see Token-based Authentication. The real-time service APIs generated by ModelArts do not support tokens whose scope is domain. Therefore, you need to obtain the token whose scope is project.
  • The local path to the inference file can be an absolute path (for example, D:/test.png for Windows and /opt/data/test.png for Linux) or a relative path (for example, ./test.png).
  • You can obtain the service URL and input parameters of a real-time service on the Usage Guides tab page of its service details page.
    The API URL is the service URL of the real-time service. If a path is defined for apis in the model configuration file, the URL must be followed by the user-defined path, for example, {URL of the real-time service}/predictions/poetry.
    Figure 1 Obtaining the API URL and file prediction input parameters of a real-time service
Method 1: Use GUI-based Software for Inference (Postman)
  1. Download Postman and install it, or install the Postman Chrome extension. Alternatively, use other software that can send POST requests. Postman 7.24.0 is recommended.
  2. Open Postman. Figure 2 shows the Postman interface.
    Figure 2 Postman interface
  3. Set parameters on Postman. The following uses image classification as an example.
    • Select a POST task and copy the API URL to the POST text box. On the Headers tab page, set Key to X-Auth-Token and Value to the user token.
      You can also use the AK and SK to encrypt API calling requests. For details, see Overview of Session Authentication.
      Figure 3 Parameter settings
    • In the Body tab, file input and text input are available.
      • File input
        Select form-data. Set KEY to the input parameter of the model, which must be the same as the input parameter of the real-time service. In this example, the KEY is images. Set VALUE to an image to be inferred (only one image can be inferred). See Figure 4.
        Figure 4 Setting parameters on the Body tab page
      • Text input
        Select raw and then JSON(application/json). Enter the request body in the text box below. An example request body is as follows:
          "meta": {
            "uuid": "10eb0091-887f-4839-9929-cbc884f1e20e"
          "data": {
            "req_data": [
                "sepal_length": 3,
                "sepal_width": 1,
                "petal_length": 2.2,
                "petal_width": 4
        meta can carry a universally unique identifier (UUID). When you call an API, the system provides a UUID. When the inference result is returned, the UUID is returned to trace the request. If you do not need this function, leave meta blank. data contains a req_data array for one or multiple pieces of input data. The parameters of each piece of data are determined by the model, such as sepal_length and sepal_width in this example.
  4. After setting the parameters, click send to send the request. The result will be displayed in Response.
    • Inference result using file input: Figure 5 shows an example. The field values in the return result vary with the model.
    • Inference result using text input: Figure 6 shows an example. The request body contains meta and data. If the request contains uuid, uuid will be returned in the response. Otherwise, uuid is left blank. data contains a resp_data array for the inference results of one or multiple pieces of input data. The parameters of each result are determined by the model, for example, sepal_length and predictresult in this example.
      Figure 5 File inference result
      Figure 6 Text inference result
Method 2: Run the cURL Command to Send an Inference Request
The command for sending inference requests can be input as a file or text.
  • File input
    curl -kv -F 'images=@Image path' -H 'X-Auth-Token:Token value' -X POST Real-time service URL
    • -k indicates that SSL websites can be accessed without using a security certificate.
    • -F indicates file input. In this example, the parameter name is images, which can be changed as required. The image storage path follows @.
    • -H indicates the header of a POST command. X-Auth-Token is the header key, which is fixed. Token value indicates the user token.
    • POST is followed by the API URL of the real-time service.
    The following is an example of the cURL command for inference with file input:
    curl -kv -F 'images=@/home/data/test.png' -H 'X-Auth-Token:MIISkAY***80T9wHQ==' -X POST https://modelarts-infers-1.xxx/v1/infers/eb3e0c54-3dfa-4750-af0c-95c45e5d3e83
  • Text input
    curl -kv -d '{"data":{"req_data":[{"sepal_length":3,"sepal_width":1,"petal_length":2.2,"petal_width":4}]}}' -H 'X-Auth-Token:MIISkAY***80T9wHQ==' -H 'Content-type: application/json' -X POST https://modelarts-infers-1.xxx/v1/infers/eb3e0c54-3dfa-4750-af0c-95c45e5d3e83
    -d indicates the text input of the request body.
Method 3: Use Python to Send an Inference Request
  1. Download the Python SDK and configure it in the development tool. For details, see Integrating the Python SDK for API request signing.
  2. Create a request body for inference.
    • File input
      # coding=utf-8
      import requests
      if __name__ == '__main__':
          # Config url, token and file path.
          url = "URL of the real-time service"
          token = "User token"
          file_path = "Local path to the inference file"
          # Send request.
          headers = {
              'X-Auth-Token': token
          files = {
              'images': open(file_path, 'rb')
          resp = requests.post(url, headers=headers, files=files)
          # Print result.
          print(resp.status_code)
          print(resp.text)
      The files name is determined by the input parameter of the real-time service. The parameter name must be the same as that of the input parameter of the file type. The input parameter images obtained in Prerequisites is an example.
    • Text input (JSON)
      The following is an example of the request body for reading the local inference file and performing Base64 encoding:
      # coding=utf-8
      import base64
      import requests
          with open(file_path, "rb") as file:
              base64_data = base64.b64encode(file.read()).decode("utf-8")
          # Set body,then send request
          headers = {
              'Content-Type': 'application/json',
          body = {
              'image': base64_data
          resp = requests.post(url, headers=headers, json=body)
          # Print result
          print(resp.text)
      The body name is determined by the input parameter of the real-time service. The parameter name must be the same as that of the input parameter of the string type. The input parameter images obtained in Prerequisites is an example. The value of base64_data in body is of the string type.
Method 4: Use Java to Send an Inference Request
  1. Download the Java SDK and configure it in the development tool. For details, see Integrating the Java SDK for API request signing.
  2. (Optional) If the input of the inference request is in the file format, the Java project depends on the httpmime module.
    1. Add httpmime-x.x.x.jar to the libs folder. Figure 7 shows a complete Java dependency library.
      You are advised to use httpmime-x.x.x.jar 4.5 or later. Download httpmime-x.x.x.jar from https://mvnrepository.com/artifact/org.apache.httpcomponents/httpmime.
      Figure 7 Java dependency library
    2. After httpmime-x.x.x.jar is added, add httpmime information to the .classpath file of the Java project as follows:
      <?xml version="1.0" encoding="UTF-8"?>
      <classpath>
      <classpathentry kind="con" path="org.eclipse.jdt.launching.JRE_CONTAINER"/>
      <classpathentry kind="src" path="src"/>
      <classpathentry kind="lib" path="libs/commons-codec-1.11.jar"/>
      <classpathentry kind="lib" path="libs/commons-logging-1.2.jar"/>
      <classpathentry kind="lib" path="libs/httpclient-4.5.13.jar"/>
      <classpathentry kind="lib" path="libs/httpcore-4.4.13.jar"/>
      <classpathentry kind="lib" path="libs/httpmime-x.x.x.jar"/>
      <classpathentry kind="lib" path="libs/java-sdk-core-3.1.2.jar"/>
      <classpathentry kind="lib" path="libs/okhttp-3.14.9.jar"/>
      <classpathentry kind="lib" path="libs/okio-1.17.2.jar"/>
      <classpathentry kind="output" path="bin"/>
      </classpath>
  3. Create a Java request body for inference.
    • File input
      A sample Java request body is as follows:
      // Package name of the demo.
      package com.apig.sdk.demo;
      import org.apache.http.Consts;
      import org.apache.http.HttpEntity;
      import org.apache.http.client.methods.CloseableHttpResponse;
      import org.apache.http.client.methods.HttpPost;
      import org.apache.http.entity.ContentType;
      import org.apache.http.entity.mime.MultipartEntityBuilder;
      import org.apache.http.impl.client.HttpClients;
      import org.apache.http.util.EntityUtils;
      import java.io.File;
      public class MyTokenFile {
              // Config url, token and filePath
              String url = "URL of the real-time service";
              String token = "User token";
              String filePath = "Local path to the inference file";
              try {
                  // Create post
                  HttpPost httpPost = new HttpPost(url);
                  // Add header parameters
                  httpPost.setHeader("X-Auth-Token", token);
                  // Add a body if you have specified the PUT or POST method. Special characters, such as the double quotation mark ("), contained in the body must be escaped.
                  File file = new File(filePath);
                  HttpEntity entity = MultipartEntityBuilder.create().addBinaryBody("images", file).setContentType(ContentType.MULTIPART_FORM_DATA).setCharset(Consts.UTF_8).build();
                  httpPost.setEntity(entity);
                  // Send post
                  CloseableHttpResponse response = HttpClients.createDefault().execute(httpPost);
                  // Print result
                  System.out.println(response.getStatusLine().getStatusCode());
                  System.out.println(EntityUtils.toString(response.getEntity()));
              } catch (Exception e) {
                  e.printStackTrace();
      The addBinaryBody name is determined by the input parameter of the real-time service. The parameter name must be the same as that of the input parameter of the file type. The file images obtained in Prerequisites is used as an example.
    • Text input (JSON)
      import org.apache.http.HttpHeaders;
      import org.apache.http.entity.StringEntity;
      public class MyTokenTest {
              // Config url, token and body
              String body = "{}";
              try {
                  // Create post
                  httpPost.setHeader(HttpHeaders.CONTENT_TYPE, "application/json");
                  // Special characters, such as the double quotation mark ("), contained in the body must be escaped.
                  httpPost.setEntity(new StringEntity(body));
                  // Send post.
                  // Print result
      body is determined by the text format. JSON is used as an example.
