Importing a Meta Model from a Container Image
For AI engines that are not supported by ModelArts, you can import the models from custom images.
- For details about the specifications and description of custom images, see Specifications for Custom Images Used for Importing Models.
- If the meta model is from a container image, ensure the size of the meta model complies with restrictions on the size of an image for importing a model.
- You must update the custom image version or enable image replication when creating an AI application. Otherwise, new applications will still use the old image version.
The OBS directory you use and ModelArts are in the same region.
- Log in to the ModelArts console and choose Model Management in the navigation pane on the left.
- Click Create Model.
- Configure parameters.
- Set basic information about the model. For details about the parameters, see Table 1.
Table 1 Basic information Parameter
Name
Model name. The value can contain 1 to 64 visible characters. Only letters, digits, hyphens (-), and underscores (_) are allowed.
Version
Model version. The default value is 0.0.1 for the first import.
NOTE:After a model is created, you can create new versions using different meta models for optimization.
Brief description of the model.
- Select the meta model source and configure related parameters. Set Meta Model Source to Container image. For details, see Table 2.
Figure 1 Importing a meta model from a container image
Table 2 Meta model source parameters Parameter
Container Image Path
Click
to import the container image. You do not need to use swr_location in the configuration file to specify the image location.
For details about how to create a custom image, see Specifications for Custom Images Used for Importing Models.
NOTE:The model image you select will be shared with the system administrator, so ensure you have the permission to share the image (images shared by other accounts are not supported). ModelArts will deploy the image as an inference service. Ensure that your image can be properly started and provide an inference API.
Container API
Set the protocol and port number of the inference API defined by the model.
Image Replication
Indicates whether to copy the model image in the container image to ModelArts.
- After this feature is disabled, the model image is not copied, models can be rapidly created, but modifying or deleting an image in the SWR source directory will affect service deployment.
- After this feature is enabled, the model image is copied, models cannot be rapidly created, and modifying or deleting an image in the SWR source directory will not affect service deployment.
NOTE:You must enable this feature if you want to use images shared by others. Otherwise, models will fail to be created.
Health Check
Specifies health check on a model. This parameter is configurable only when a health check API is configured in the custom image. Otherwise, the model creation will fail. The following probes are supported:
- Startup Probe: This probe checks if the application instance has started. If a startup probe is provided, all other probes are disabled until it succeeds. If the startup probe fails, the instance is restarted. If no startup probe is provided, the default status is Success.
- Readiness Probe: This probe verifies whether the application instance is ready to handle traffic. If the readiness probe fails (meaning the instance is not ready), the instance is taken out of the service load balancing pool. Traffic will not be routed to the instance until the probe succeeds.
- Liveness Probe: This probe monitors the application health status. If the liveness probe fails (indicating the application is unhealthy), the instance is automatically restarted.
The parameters of the three types of probes are as follows:
- Check Mode: Select HTTP request or Command.
- Health Check URL: Enter the health check URL, which defaults to /health. This parameter is displayed when Check Mode is set to HTTP request.
- Health Check Command: Enter the health check command. This parameter is displayed when Check Mode is set to Command.
- Health Check Period (s): Enter an integer ranging from 1 to 2147483647.
- Delay (s): Set a delay for the health check to occur after the instance has started. The value should be an integer between 0 and 2147483647.
- Timeout (s): Set the timeout interval for each health check. The value should be an integer between 0 and 2147483647.
- Maximum Failures: Enter an integer ranging from 1 to 2147483647. If the service fails the specified number of consecutive health checks during startup, it will enter the abnormal state. If the service fails the specified number of consecutive health checks during operation, it will enter the alarm state.
NOTE:If health check is enabled for a model, the associated services will stop three minutes after receiving the stop instruction.
Model Description
Model descriptions to help other developers better understand and use your model. Click Add Model Description and set the document name and URL. You can add up to three descriptions.
Deployment Type
Choose the service types for model deployment. The service types you select will be the only options available for deployment. For example, selecting Real-Time Services means the model can only be deployed as real-time services.
Start Command
Customizable start command of a model.
NOTE:Start commands containing $, |, >, <, `, !, \n, \, ?, -v, --volume, --mount, --tmpfs, --privileged, or --cap-add will be emptied when a model is being published.
API Configuration
After enabling this feature, you can edit RESTful APIs to define the input and output formats of a model. The model APIs must comply with ModelArts specifications. For details, see the apis parameter description in Specifications for Editing a Model Configuration File. For details about the code example, see Code Example of apis Parameters.
- Confirm the configurations and click Create now.
In the model list, you can view the created model and its version. When the status changes to Normal, the model is created. On this page, you can perform such operations as creating new versions and quickly deploying services.
Follow-Up Operations
Deploying a service: In the model list, click Deploy in the Operation column of the target model. Locate the target version, click Deploy and choose a service type selected during model creation.
