Connecting to a Notebook Instance Through VS Code
VS Code is a typical code editor that supports multiple programming languages and development environments. You can connect to and use Jupyter Notebook through VS Code.
After creating a notebook instance with remote SSH enabled, you can use VS Code to access the development environment in any of the following ways:
- Connecting to a Notebook Instance Through VS Code Toolkit
In this mode, log in to the ModelArts VS Code Toolkit plug-in and use it to connect to an instance.
 - Manually Connecting to a Notebook Instance Through VS Code
In this mode, use the VS Code Remote-SSH plug-in to configure connection information and connect to an instance.
Installing VS Code
Install VS Code first.
- Download URL:
    Download address: https://code.visualstudio.com/updates/v1_85Figure 1 VS Code download URL
      - VS Code version requirements:
You are advised to use VS Code 1.85.2 or the latest version for remote connection.
 - VS Code installation guide:
In Windows, double-click the installation package to complete the installation.
In Linux, run the command sudo dpkg -i code_1.85.2-1705561292_amd64.deb to install VS Code.
     Linux system users must install VS Code as a non-root user.
