Updated on 2026-07-02 GMT+08:00
Common Functions of JupyterLab
Introduction
To access JupyterLab from a running notebook instance, perform the following operations:
  1. Log in to the ModelArts console. In the navigation pane on the left, choose Development Workspace > Notebook.
  2. Locate a running notebook instance and click Access Environment in the Operation column. In the displayed dialog box, click Access next to JupyterLab Access.
  3. The Launcher page is automatically displayed. Perform required operations. For details, see JupyterLab Documentation.
    Figure 1 JupyterLab homepage
    The notebook and console kernels and versions displayed on the Launcher page vary depending on the AI engine based on which a notebook instance is created. Figure 1 shows an example only. Obtain the notebook and console kernels and versions on the management console.
    • Notebook: Select a kernel for running notebook, for example, TensorFlow or Python.
    • Console: Call the terminal for command control.
    • Other: Edit other files.
Creating a Terminal in JupyterLab
You can run Python commands on the terminal to operate the terminal. The following describes how to open the terminal of JupyterLab.
  1. Create a notebook instance. When it is in the Running state, locate it in the list and click Access Environment in the Operation column. In the displayed dialog box, click Access next to JupyterLab Access. For details, see Using JupyterLab to Develop and Debug Code Online.
  2. Choose File > New > Terminal. The Terminal page is displayed.
    Figure 2 Terminal
    You can view the operation prompt in Terminal. Exercise caution when using plaintext passwords and hard-coded AK/SK. Do not enter sensitive information in commands.
    Figure 3 Terminal
  3. You can use pip to install external libraries in the TensorFlow-1.8 environment on the Terminal page. For example, to install Shapely:
    Enter the following commands in the code input box to obtain the kernel of the current environment and activate the Python environment on which the installation depends:
    cat /home/ma-user/README
    source /home/ma-user/anaconda3/bin/activate TensorFlow-1.8
    To install TensorFlow in another Python environment, replace TensorFlow-1.8 in the command with the target engine.
    Figure 4 Activating the environment
    Run the following command in the code input box to install Shapely:
    pip install Shapely
Creating an IPYNB File in JupyterLab
On the JupyterLab homepage, click a proper AI engine in the Notebook area to create an IPYNB file.
The AI engines supported by each notebook instance vary depending on the runtime environment. The following figure is only an example. Select an AI engine based on site requirements.
Figure 5 Selecting an AI engine and creating IPYNB file
The created IPYNB file is displayed in the navigation pane on the left.
Figure 6 Created IPYNB file
Creating a Notebook File and Accessing the Console
A console is a Python terminal, which is similar to the native IDE of Python, displaying the output after a statement is entered.
On the JupyterLab homepage, click a proper AI engine in the Console area to create a notebook file.
Figure 7 Selecting an AI engine and creating a console
After the file is created, the console page is displayed.
Figure 8 Creating a notebook file (console)
Editing a File in JupyterLab
JupyterLab allows you to open multiple notebook instances or files (such as HTML, TXT, and Markdown files) in one window and displays them on different tab pages.
In JupyterLab, you can customize the display of multiple files. In the file display area on the right, you can drag a file to adjust its position. Multiple files can be concurrently displayed.
Figure 9 Customized display of multiple files
When writing code in a notebook instance, you can create multiple views of a file to synchronously edit the file and view execution results in real time.
To open multiple views, open an IPYNB file and choose File > New View for Notebook.
Figure 10 Multiple views of a file
Before coding in the code area of an IPYNB file in JupyterLab, add an exclamation mark (!) before the code.
For example, install an external library Shapely.
!pip install Shapely
For example, obtain PythonPath.
!echo $PYTHONPATH
Figure 11 Running code
Renewing or Automatically Stopping a Notebook Instance
If you enable auto stop when you created or started a notebook instance, the remaining duration for stopping the instance is displayed in the upper right corner of JupyterLab. You can click the time for renewal.
Figure 12 Remaining duration
Figure 13 Renewing an instance
Common JupyterLab Buttons and Plug-ins
Figure 14 Common JupyterLab buttons and plug-ins
Table 1 JupyterLab buttons
Button
Quickly open notebook instances and terminals. Open the Launcher page, on which you can quickly create notebook instances, consoles, or other files.
Create a folder.
Refresh the file directory.
Git plug-in, which can be used to access the GitHub code library associated with the notebook instance.
Switch the file filter.
Upload files.
Table 2 JupyterLab plug-ins
Plug-in
List files. Click this button to show all files in the notebook instance.
Display the terminals and kernels that are running in the current instance.
Git plug-in, which can be used to quickly access the GitHub code library.
Property inspector.
Show the document organization.
Figure 15 Buttons in the navigation bar
Table 3 Buttons in the navigation bar
Button
File
Actions related to files and directories, such as creating, closing, or saving notebooks.
Edit
Actions related to editing documents and other activities in the IPYNB file, such as undoing, redoing, or cutting cells.
View
Actions that alter the appearance of JupyterLab, such as showing the bar or expanding code.
Run
Actions for running code in different activities such as notebooks and code consoles.
Kernel
Actions for managing kernels, such as interrupting, restarting, or shutting down a kernel.
Git
Actions on the Git plug-in, which can be used to quickly access the GitHub code library.
Tabs
A list of the open documents and activities in the dock panel.
Settings
Common settings and an advanced settings editor.
Help
A list of JupyterLab and kernel help links.
Figure 16 Buttons in the menu bar of an IPYNB file
Table 4 Buttons in the menu bar of an IPYNB file
Button
Save a file.
Add a new cell.
Cut the selected cell.
Copy the selected cell.
Paste the selected cell.
Execute the selected cell.
Terminate a kernel.
Restart a kernel.
Restart a kernel and run all code of the current notebook again.
There are four options in the drop-down list:
Code (Python code), Markdown (Markdown code, typically used for comments), Raw (a conversion tool), and - (not modified)
View historical code versions.
Git plug-in. The gray button indicates that the plug-in is unavailable in the current region.
Instance flavor.
Kernel for you to select.
Code running status. indicates the code is being executed.
Using Code-based Plug-ins
The code parametrization plug-in simplifies notebook cases. You can quickly adjust parameters and train models based on notebook cases without complex code. This plug-in can be used to customize notebook cases for competitions and learning.
  • The Add Form and Edit Form buttons are available only to the shortcut menu of code cells, as shown below.
    Figure 17 Viewing a code cell
  • After opening new code, add a form before editing it.
    Figure 18 Shortcut menu of code cells
  • If you click Add Form, a code cell will be split into the code and form edit area. Click Edit on the right of the form to change the default title.
    Figure 19 Two edit areas
  • If you click Edit Form, four sub-options will be displayed: Add new form field, Hide code, Hide form, and Show All.
    Table 5 Edit Form sub-options
    Edit-Form Sub-option
    Add new form field
    • The form field types include dropdown, input, and slider, Each time a field is added, as shown in Figure 20, the corresponding variable is added to the code and form areas. If a value in the form area is changed, the corresponding variable in the code area is also changed.
    When creating a dropdown form, click ADD Item and add at least two items, as shown in Figure 21.
    • If the form field type is set to dropdown, the supported variable types are raw and string.
    • If the form field type is set to input, the supported variable types are boolean, date, integer, number, raw, and string.
    • If the form field type is set to slider, the minimum value, maximum value, and step can be set.
    Hide code
    Hide the code.
    Hide form
    Hide the forms.
    Show all
    Display both code and forms.
    Figure 20 Form field types
    Figure 21 Creating a dropdown form
    Figure 22 Deleting a form
Monitoring Resources
To obtain resource usage, select Resource Monitor in the right pane. The CPU usage and memory usage are displayed.
Figure 23 Resource usage
