Updated on 2025-06-06 GMT+08:00
Dynamically Mounting an OBS Parallel File System
Overview
A parallel file system is an optimized high-performance file system provided by Object Storage Service (OBS). For details, see About Parallel File System.
Dynamic OBS mounting uses a mounting tool to convert the object storage protocol into the POSIX file protocol. OBS storage is simulated as a local file system and dynamically mounted to a running notebook container in ModelArts. After the mounting, you can perform application operations on the OBS objects in the notebook container.
Application Scenarios
Scenario 1: After you mount the OBS storage in which the target dataset is stored to your notebook instance, you can preview and perform operations in the dataset like operating a local file system.
Scenario 2: When training data in a notebook instance, you can use the dataset mounted to a notebook container.
Restrictions
  • OBS provides object buckets and parallel file systems for storage. The ModelArts notebook supports only the mounting of an OBS parallel file system to /data/ of a notebook container.
  • On the international website, dynamic mounting of OBS parallel file systems is supported only in CN-Hong Kong, AP-Bangkok, and AP-Singapore.
Method 1: Through the ModelArts management console
  1. Log in to the ModelArts management console. In the navigation pane on the left, choose Development Workspace > Notebook.
  2. Select a running notebook instance and click its name. On the notebook instance details page, click the Storage tab. From there, click Mount Storage and configure mounting parameters.
    1. Set a local mounting directory. Enter a folder name in /data/, for example, demo. The system will automatically create the folder in /data/ of the notebook container to mount the OBS file system.
    2. Select the folder for storing the OBS parallel file system and click OK.
      Figure 1 Dynamically mounting an OBS parallel file system
  3. View the mounting result on the notebook instance details page.
    Figure 2 Successful mounting
