Viewing the Model Evaluation Result
Updated on 2024-10-29 GMT+08:00
After a training job has been executed, ModelArts evaluates your model and provides optimization diagnosis and suggestions.
  • When you use a built-in algorithm to create a training job, you can view the evaluation result without any configurations. The system automatically provides optimization suggestions based on your model metrics. Read the suggestions and guidance on the page carefully to further optimize your model.
  • For a training job created by writing a training script or using a custom image, you need to add the evaluation code to the training code so that you can view the evaluation result and diagnosis suggestions after the training job is complete.
    • Only validation sets of the image type are supported.
    • You can add the evaluation code only when the training scripts of the following frequently-used frameworks are used:
      • TF-1.13.1-python3.6
      • TF-2.1.0-python3.6
      • PyTorch-1.4.0-python3.6
This section describes how to use the evaluation code in a training job. To adapt and modify the training code, three steps are involved, Adding the Output Path, Copying the Dataset to the Local Host, and Mapping the Dataset Path to OBS.
The code for adding the output path is simple. That is, add a path for storing the evaluation result file to the code, which is called train_url, that is, the training output path on the console. Add train_url to the analysis function and use save_path to obtain train_url. The sample code is as follows:
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
FLAGS = tf.app.flags.FLAGS
tf.app.flags.DEFINE_string('model_url', '', 'path to saved model')
tf.app.flags.DEFINE_string('data_url', '', 'path to output files')
tf.app.flags.DEFINE_string('train_url', '', 'path to output files')
tf.app.flags.DEFINE_string('adv_param_json',
                           '{"attack_method":"FGSM","eps":40}',
                           'params for adversarial attacks')
FLAGS(sys.argv, known_only=True)
# analyse
res = analyse(
    task_type=task_type,
    pred_list=pred_list,
    label_list=label_list,
    name_list=file_name_list,
    label_map_dict=label_dict,
    save_path=FLAGS.train_url)
Copying a dataset to the local host is to prevent the OBS connection from being interrupted due to long-time access. Therefore, copy the dataset to the local host before performing operations.
There are two methods for copying datasets. The recommended method is to use the OBS path.
  • OBS path (recommended)
    Call the copy_parallel API of MoXing to copy the corresponding OBS path.
  • Dataset in ModelArts data management (manifest file format)
    Call the copy_manifest API of MoXing to copy the file to the local host and obtain the path of the new manifest file. Then, use SDK to parse the new manifest file.
ModelArts data management is being upgraded and is invisible to users who have not used data management. It is recommended that new users store their training data in OBS buckets.
3
4
5
6
7
8
if data_path.startswith('obs://'):
    if '.manifest' in data_path:
        new_manifest_path, _ = mox.file.copy_manifest(data_path, '/cache/data/')
        data_path = new_manifest_path
    else:
        mox.file.copy_parallel(data_path, '/cache/data/')
        data_path = '/cache/data/'
    print('------------- download dataset success ------------')
The actual path of the image file, that is, the OBS path, needs to be entered in the JSON body. Therefore, after analysis and evaluation are performed on the local host, the original local dataset path needs to be mapped to the OBS path, and the new list needs to be sent to the analysis API.
If the OBS path is used as the input of data_url, you only need to replace the string of the local path.
3
if FLAGS.data_url.startswith('obs://'):
    for idx, item in enumerate(file_name_list):
        file_name_list[idx] = item.replace(data_path, FLAGS.data_url)
If the manifest file is used, the original manifest file needs to be parsed again to obtain the list and then the list is sent to the analysis API.
3
4
5
6
7
8
if or FLAGS.data_url.startswith('obs://'):
    if 'manifest' in FLAGS.data_url:
            file_name_list = []
            manifest, _ = get_sample_list(
                manifest_path=FLAGS.data_url, task_type='image_classification')
            for item in manifest:
                if len(item[1]) != 0:
                    file_name_list.append(item[0])
An example code for image classification that can be used to create training jobs is as follows:
  3
  4
  5
  6
  7
  8
  9
 10
 11
 12
 13
 14
 15
 16
 17
 18
 19
 20
 21
 22
 23
 24
 25
 26
 27
 28
 29
 30
 31
 32
 33
 34
 35
 36
 37
 38
 39
 40
 41
 42
 43
 44
 45
 46
 47
 48
 49
 50
 51
 52
 53
 54
 55
 56
 57
 58
 59
 60
 61
 62
 63
 64
 65
 66
 67
 68
 69
 70
 71
 72
 73
 74
 75
 76
 77
 78
 79
 80
 81
 82
 83
 84
 85
 86
 87
 88
 89
 90
 91
 92
 93
 94
 95
 96
 97
 98
 99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
import json
import logging
import os
import sys
import tempfile
import h5py
import numpy as np
from PIL import Image
import moxing as mox
import tensorflow as tf
from deep_moxing.framework.manifest_api.manifest_api import get_sample_list
from deep_moxing.model_analysis.api import analyse, tmp_save
from deep_moxing.model_analysis.common.constant import TMP_FILE_NAME
logging.basicConfig(level=logging.DEBUG)
def _preprocess(data_path):
    img = Image.open(data_path)
    img = img.convert('RGB')
    img = np.asarray(img, dtype=np.float32)
    img = img[np.newaxis, :, :, :]
    return img
def softmax(x):
    x = np.array(x)
    orig_shape = x.shape
    if len(x.shape) > 1:
        # Matrix
        x = np.apply_along_axis(lambda x: np.exp(x - np.max(x)), 1, x)
        denominator = np.apply_along_axis(lambda x: 1.0 / np.sum(x), 1, x)
        if len(denominator.shape) == 1:
            denominator = denominator.reshape((denominator.shape[0], 1))
        x = x * denominator
    else:
        # Vector
        x_max = np.max(x)
        x = x - x_max
        numerator = np.exp(x)
        denominator = 1.0 / np.sum(numerator)
        x = numerator.dot(denominator)
    assert x.shape == orig_shape
    return x
def get_dataset(data_path, label_map_dict):
    label_list = []
    img_name_list = []
    if 'manifest' in data_path:
            manifest_path=data_path, task_type='image_classification')
                label_list.append(label_map_dict.get(item[1][0]))
                img_name_list.append(item[0])
            else:
                continue
    else:
        label_name_list = os.listdir(data_path)
        label_dict = {}
        for idx, item in enumerate(label_name_list):
            label_dict[str(idx)] = item
            sub_img_list = os.listdir(os.path.join(data_path, item))
            img_name_list += [
                os.path.join(data_path, item, img_name) for img_name in sub_img_list
            label_list += [label_map_dict.get(item)] * len(sub_img_list)
    return img_name_list, label_list
def deal_ckpt_and_data_with_obs():
    pb_dir = FLAGS.model_url
    data_path = FLAGS.data_url
    if pb_dir.startswith('obs://'):
        mox.file.copy_parallel(pb_dir, '/cache/ckpt/')
        pb_dir = '/cache/ckpt'
        print('------------- download success ------------')
        else:
    assert os.path.isdir(pb_dir), 'Error, pb_dir must be a directory'
    return pb_dir, data_path
def evalution():
    pb_dir, data_path = deal_ckpt_and_data_with_obs()
    index_file = os.path.join(pb_dir, 'index')
    try:
        label_file = h5py.File(index_file, 'r')
        label_array = label_file['labels_list'][:].tolist()
        label_array = [item.decode('utf-8') for item in label_array]
    except Exception as e:
        logging.warning(e)
        logging.warning('index file is not a h5 file, try json.')
        with open(index_file, 'r') as load_f:
            label_file = json.load(load_f)
    label_map_dict = {}
    label_dict = {}
    for idx, item in enumerate(label_array):
        label_map_dict[item] = idx
        label_dict[idx] = item
    print(label_map_dict)
    print(label_dict)
    data_file_list, label_list = get_dataset(data_path, label_map_dict)
    assert len(label_list) > 0, 'missing valid data'
    assert None not in label_list, 'dataset and model not match'
    pred_list = []
    file_name_list = []
    img_list = []
    for img_path in data_file_list:
        img = _preprocess(img_path)
        img_list.append(img)
        file_name_list.append(img_path)
    config = tf.ConfigProto()
    config.gpu_options.allow_growth = True
    config.gpu_options.visible_device_list = '0'
    with tf.Session(graph=tf.Graph(), config=config) as sess:
        meta_graph_def = tf.saved_model.loader.load(
            sess, [tf.saved_model.tag_constants.SERVING], pb_dir)
        signature = meta_graph_def.signature_def
        signature_key = 'predict_object'
        input_key = 'images'
        output_key = 'logits'
        x_tensor_name = signature[signature_key].inputs[input_key].name
        y_tensor_name = signature[signature_key].outputs[output_key].name
        x = sess.graph.get_tensor_by_name(x_tensor_name)
        y = sess.graph.get_tensor_by_name(y_tensor_name)
        for img in img_list:
            pred_output = sess.run([y], {x: img})
            pred_output = softmax(pred_output[0])
            pred_list.append(pred_output[0].tolist())
    label_dict = json.dumps(label_dict)
    task_type = 'image_classification'
            file_name_list = []
    # analyse
    res = analyse(
if __name__ == "__main__":
    evalution()
