Creating an Algorithm
Machine learning explores general rules from limited volume of data and uses these rules to predict unknown data. To obtain more accurate prediction results, select a proper algorithm to train your model. ModelArts provides a large number of algorithm samples for different scenarios. This section describes algorithm sources and learning modes.
Algorithm Sources
ModelArts provides the following algorithm sources for model training:
- Using a subscribed algorithm
You can directly subscribe to algorithms in ModelArts AI Gallery and use them to build models without writing code.
- Using a preset image
To use a custom algorithm, use a framework built in ModelArts. ModelArts supports most mainstream AI engines. For details, see Starting Training Using a Preset Image's Boot File. These built-in engines pre-load some extra Python packages, such as NumPy. You can also use the requirements.txt file in the code directory to install dependency packages. For details about how to create a training job using a preset image, see Developing Code for Training Using a Preset Image.
- Using a preset image with customization
If you use a preset image to create an algorithm and you need to modify or add some software dependencies based on the preset image, you can customize the preset image. In this case, select a preset image and choose Customize from the framework version drop-down list box.
The only difference between this method and creating an algorithm totally based on a preset image is that you must select an image. You can create a custom image based on a preset image.
- Using a custom image
The subscribed algorithms and preset images can be used in most training scenarios. In certain scenarios, ModelArts allows you to create custom images to train models. You can create an image based on the ModelArts image specifications, select your own image and configure the code directory (optional) and boot command to create a training job.
Custom images can be used to train models in ModelArts only after they are uploaded to Software Repository for Container (SWR). For details, see Creating a Custom Training Image. Customizing an image requires a deep understanding of containers. Use this method only if the subscribed algorithms and custom scripts cannot meet your requirements.
When you use a custom image to create a training job, the boot command must be executed in the /home/ma-user directory. Otherwise, the training job may run abnormally.
Your locally developed algorithms or algorithms developed using other tools can be uploaded to ModelArts for unified management.
- Make preparations.
- Create a dataset in ModelArts or upload a training dataset to an OBS directory.
- Your training script has been uploaded to an OBS directory. For details about how to develop a training script, see Developing Code for Training Using a Preset Image or Developing Code for Training Using a Custom Image.
- Create at least one empty folder in OBS for storing training outputs.
- Make sure your OBS directory and ModelArts are in the same region.
- Access the algorithm creation page.
- Log in to the ModelArts console. In the navigation pane, choose Asset Management > Algorithm Management.
- In the My algorithm tab, click Create Algorithm. Enter the basic algorithm information, including Name and Description.
- Set the algorithm boot mode. The options are as follows:
Figure 1 Using a preset image to create an algorithm
Set Code Directory and Boot File based on the algorithm code. Ensure that the preset image you select is the same as the one you use for editing algorithm code. For example, if TensorFlow is used for writing algorithm code, select TensorFlow when you create an algorithm.Table 1 Parameters Parameter
Boot Mode
Select Preset image.
Select a preset image and its version used by the algorithm.
Code Directory
Select an OBS path for storing the algorithm code. The files required for training, such as the training code, dependency installation packages, and pre-generated models, are uploaded to the code directory.
Do not store training data in the code directory. When the training job starts, the data stored in the code directory will be downloaded to the backend. A large amount of training data may lead to a download failure.
After you create the training job, ModelArts downloads the code directory and its subdirectories to the training container.
Take OBS path obs://obs-bucket/training-test/demo-code as an example. The content in the OBS path will be automatically downloaded to ${MA_JOB_DIR}/demo-code in the training container, and demo-code (customizable) is the last-level directory of the OBS path.
NOTE:- Any programming language is supported.
- The total number of both files and folders cannot exceed 1,000.
- The total size of files cannot exceed 5 GB.
Boot File
The file must be stored in the code directory and end with .py. ModelArts supports boot files edited only in Python.
The boot file in the code directory is used to start a training job.
Figure 2 Creating an algorithm using a preset image with customization
Set Image, Code Directory, and Boot File based on the algorithm code. Ensure that the preset image you select is the same as the one you use for editing algorithm code. For example, if TensorFlow is used for writing algorithm code, select TensorFlow when you create an algorithm.Table 2 Parameters Parameter
Boot Mode
Select Customize for the engine version.
Select your image uploaded to SWR. For details about how to create an image, see Creating a Custom Training Image.
Code Directory
When the training job starts, ModelArts downloads the training code directory and its subdirectories to the training container.
NOTE:- Any programming language is supported for training code. The training boot file must be a Python file.
- The file depth cannot exceed 32.
Boot File
Selecting a preset image with customization results in the same background behavior as running a training job directly with that image. For example:- The system automatically injects environment variables.
PATH=${MA_HOME}/anaconda/bin:${PATH} LD_LIBRARY_PATH=${MA_HOME}/anaconda/lib:${LD_LIBRARY_PATH} PYTHONPATH=${MA_JOB_DIR}:${PYTHONPATH} - The selected boot file will be automatically started using Python commands. Ensure that the Python environment is correct. The PATH environment variable is automatically injected. Run the following commands to check the Python version for the training job:
export MA_HOME=/home/ma-user; docker run --rm {image} ${MA_HOME}/anaconda/bin/python -V docker run --rm {image} $(which python) -V - The system automatically adds hyperparameters associated with the preset image.
Figure 3 Creating an algorithm using a custom image
Table 3 Parameters Parameter
Boot Mode
Select Custom image.
Code Directory
Select an OBS path for storing the algorithm code. The files required for training, such as the training code, dependency installation packages, and pre-generated models, are uploaded to the code directory. Configure this parameter only if your custom image does not contain training code.
Boot Command
Command for booting an image. This parameter is mandatory.
When a training job is running, the boot command is automatically executed after the code directory is downloaded.- If the training boot script is a .py file, train.py for example, the boot command is as follows.
python ${MA_JOB_DIR}/demo-code/train.py - If the training boot script is a .sh file, main.sh for example, the boot command is as follows:
bash ${MA_JOB_DIR}/demo-code/main.sh
You can use semicolons (;) and ampersands (&&) to combine multiple commands. demo-code in the command is the last-level OBS directory where the code is stored. Replace it with the actual one.
If there are input pipes, output pipes, or hyperparameters, ensure that the last command of the boot command runs the training script.
Reason: The system appends input pipes, output pipes, and hyperparameters to the end of the boot command. If the last command is not the training script, an error will occur.
Example: If the last line of the boot command is python train.py and the --data_url hyperparameter exists, the system executes python train.py --data_url=/input when running properly. However, if the boot command ends with another command, such as:
python train.py pwd # The last command is pwd instead of the training script.
The system will execute python train.py pwd --data_url=/input, leading to an error.
For details about how to use custom images supported by training, see Boot Command Specifications for Custom Images.
- Configure pipelines.
An algorithm obtains data from an OBS bucket or dataset for model training. The training output is stored in an OBS bucket. The input and output parameters in your algorithm code must be parsed to enable data exchange between ModelArts and OBS. For details about how to develop code for training on ModelArts, see Preparing Model Training Code.
- Input configurations
Table 4 Input configurations Parameter
Parameter Name
Set this parameter based on the data input parameter in your algorithm code. The code path parameter must be the same as the training input parameter parsed in your algorithm code. Otherwise, the algorithm code cannot obtain the input data.
For example, If you use argparse in the algorithm code to parse data_url into the data input, set the data input parameter to data_url when creating the algorithm.
Customize the description of the input parameter.
Obtained from
Select a source of the input parameter, Hyperparameters (default) or Environment variables.
Enable this parameter to specify the input source. You can select a storage path or ModelArts dataset. This parameter is optional.
If you select a ModelArts dataset, set the following parameters:- Labeling Type: For details, see Creating a Manual Labeling Job.
- Data Format, which can be Default, CarbonData, or both. Default indicates the manifest format.
- Data Segmentation is available only for image classification, object detection, text classification, and sound classification datasets.
The options are Segmented dataset, Dataset not segmented, and Unlimited. For details, see Publishing a Data Version.
Add
Add multiple input data sources based on your algorithm.
- Output configurations
Table 5 Output configurations Parameter
Parameter Name
Set this parameter based on the data output parameter in your algorithm code. The code path parameter must be the same as the data output parameter parsed in your algorithm code. Otherwise, the algorithm code cannot obtain the output path.
For example, if you use argparse in the algorithm code to parse train_url into the data output, set the data output parameter to train_url when creating the algorithm.
Customize the description of the output parameter.
Obtained from
Select a source of the output parameter, Hyperparameters (default) or Environment variables.
Add
Add multiple output data paths based on your algorithm.
- Define hyperparameters.
When you create an algorithm, ModelArts allows you to customize hyperparameters so you can view or modify them anytime. Defined hyperparameters are displayed in the boot command and passed to your boot file as CLI parameters.
- Edit hyperparameters.
To ensure data security, do not enter sensitive information, such as plaintext passwords.
Table 6 Editing hyperparameters Parameter
Name
Enter the hyperparameter name.
Enter 1 to 64 characters. Only letters, digits, hyphens (-), and underscores (_) are allowed.
Type
Select the data type of the hyperparameter. The value can be String, Integer, Float, or Boolean
Default
Set the default value of the hyperparameter. This value will be used for training jobs by default.
Restrain
Click Restrain. Then, set the range of the default value or enumerated value in the dialog box displayed.
Required
Select Yes or No.
- If you select No, you can delete the hyperparameter on the training job creation page when using this algorithm to create a training job.
- If you select Yes, you cannot delete the hyperparameter on the training job creation page when using this algorithm to create a training job.
Enter the description of the hyperparameter.
Only letters, digits, spaces, hyphens (-), underscores (_), commas (,), and periods (.) are allowed.
- Configure supported policies.
Auto search on ModelArts automatically finds the optimal hyperparameters without any code modification. For details about parameter settings, see Creating a Training Job for Automatic Model Tuning.
Only the tensorflow_2.1.0-cuda_10.1-py_3.7-ubuntu_18.04-x86_64 and pytorch_1.8.0-cuda_10.2-py_3.7-ubuntu_18.04-x86_64 images are available for auto search.
- Add training constraints.
You can add training constraints of the algorithm based on your needs.
- Resource Type: Select the required resource types.
- Multicard Training: Choose whether to support multi-PU training.
- Distributed Training: Choose whether to support distributed training.
- Click Submit.
In the algorithm list, click the algorithm to access its details page and view the algorithm details.
- In the Basic Information tab, you can view the algorithm information.
In the Basic Information tab, click Edit to modify algorithm information except the name and ID. After the modification, click Save.
- In the Training tab, you can view the information about the training jobs that use the algorithm, such as the training job name and status.
Previewing the Runtime Environment
When creating an algorithm, click the arrow on
in the lower right corner of the page to know the paths of the code directory, boot file, and input and output data in the training container.
Deleting an Algorithm
Deleted algorithm assets cannot be restored.
To delete your algorithm, choose Asset Management > Algorithm Management. Click Delete in the Operation column. In the displayed dialog box, enter DELETE, and click OK to confirm the deletion.
To delete a subscribed algorithm, go to AI Gallery, choose My Assets > Algorithm, click My Subscription, and click Cancel Subscription for the algorithm you want to delete. In the displayed dialog box, click OK.
