On this page
Show all
Introduction to Importing Data from OBS
Updated on 2024-12-31 GMT+08:00
Import Modes
You can import data from OBS through an OBS path or a manifest file.
  • OBS path: indicates that the dataset to be imported has been stored in an OBS path. In this case, select an OBS path that you can access. In addition, the directory structure in the OBS path must comply with the specifications. For details, see Specifications for Importing Data from an OBS Directory. This import mode is available only for the following types of datasets: Image classification, Object detection, Text classification, Table, and Sound classification. For other types of datasets, data can be imported only through a manifest file.
  • Manifest file: indicates that the dataset file is in the manifest format and the manifest file has been uploaded to OBS. The manifest file defines the mapping between labeling objects and content. For details about the specifications of manifest files, see Specifications for Importing a Manifest File.
Before importing an object detection dataset, ensure that the labeling range of the labeling file does not exceed the size of the original image. Otherwise, the import may fail.
Table 1 Import modes supported by datasets
Dataset Type
Labeling Type
From an OBS Path
From a Manifest File
Images
Supported
You can import unlabeled or labeled data.
Format specifications of labeled data: Image Classification
Supported
Object detection
Supported
Format specifications of labeled data: Object Detection
Supported
Image segmentation
Supported
Format specifications of labeled data: Image Segmentation
Supported
Audio
Supported
Follow the format specifications described in Sound Classification.
Supported
Format specifications of labeled data: Sound Classification
Speech labeling
Supported
You can import unlabeled data.
Supported
Format specifications of labeled data: Speech Labeling
Speech paragraph labeling
Supported
Supported
Format specifications of labeled data: Speech Paragraph Labeling
Text
Text classification
Supported
Format specifications of labeled data: Text Classification
Supported
Named entity recognition
Supported
Supported
Format specifications of labeled data: Named Entity Recognition
Text triplet
Supported
Supported
Format specifications of labeled data: Text Triplet
Video
Video labeling
Supported
Supported
Format specifications of labeled data: Video Labeling
Other
Free format
Supported
N/A
Table
Table
Supported
You can also import data from DWS, DLI, or MRS.
Follow the format specifications described in Tables.
N/A
