Dataset Overview
Updated on 2024-12-31 GMT+08:00
Dataset Types
ModelArts supports the following types of datasets:
  • Images: in .jpg, .png, .jpeg, or .bmp format for image classification, image segmentation, and object detection
  • Audio: in .wav format for sound classification, speech labeling, and speech paragraph labeling
  • Text: in .txt or .csv format for text classification, named entity recognition, and text triplet labeling
  • Video: in .mp4 format for video labeling
  • Free format: allows data in any format. Labeling is not available for free format data. The free format applies if labeling is not required or needs to be customized. Select this format if your data is in multiple formats or your data is not in any of the preceding formats.
  • Tables
    Table: applies to structured data processing such as tables. The file format can be CSV. Tables cannot be labeled but you can preview up to 100 data records in a table.
Dataset Functions
Different types of datasets support different functions, such as auto labeling and team labeling. For details, see Table 1.
Table 1 Functions supported by different types of datasets
Dataset Type
Labeling Type
Creating a Dataset
Importing Data
Exporting Data
Publishing a Dataset
Modifying a Dataset
Managing Dataset Versions
Auto Grouping
Data Features
Image classification
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Object detection
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Supported
Image segmentation
Supported
Supported
Supported
Supported
Supported
Supported
Supported
N/A
Audio
Sound classification
Supported
Supported
N/A
Supported
Supported
Supported
N/A
N/A
Speech labeling
Supported
Supported
N/A
Supported
Supported
Supported
N/A
N/A
Speech paragraph labeling
Supported
Supported
N/A
Supported
Supported
Supported
N/A
N/A
Text
Text classification
Supported
Supported
N/A
Supported
Supported
Supported
N/A
N/A
Named entity recognition
Supported
Supported
N/A
Supported
Supported
Supported
N/A
N/A
Text triplet
Supported
Supported
N/A
Supported
Supported
Supported
N/A
N/A
Video
Video labeling
Supported
Supported
N/A
Supported
Supported
Supported
N/A
N/A
Free format
Free format
Supported
N/A
_
Supported
Supported
Supported
N/A
N/A
Table
Table
Supported
Supported
N/A
Supported
Supported
Supported
N/A
N/A
Specifications Restrictions
  • The maximum numbers of samples and labels in a single text, video, or audio database other than a table dataset are 1,000,000 and 10,000, respectively.
  • The maximum size of a sample in a single text, video, or audio database other than an image dataset is 5 GB.
  • The maximum size of an image for object detection, image segmentation, or image classification is 25 MB.
  • The maximum size of a manifest file is 5 GB.
  • The maximum size of a text file in a line is 100 KB.
  • The maximum size of a labeling result file is 100 MB.
