- What's New
- Function Overview
- Getting Started
User Guide
- Topic Management
- Subscription Management
- Message Template Management
- SMN Operation Recording
- Cloud Eye Monitoring
- Logs
- Permissions Management
- Quotas
- Appendix
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- APIs
- Examples
- Public Parameters
- Out-of-Date APIs
- Appendix
- SDK Reference
- What Are the Advantages of SMN?
- What Protocols Does SMN Support?
- How Is SMN Billed?
- What Are the Requirements for an SMN Topic Name?
- How Many Topics Can I Create?
- How Many Subscriptions Can Be Added to a Topic?
- How Many Messages Can Be Published to a Topic?
- How Many Message Templates Can I Create?
- What Are the Limitations on SMS Messages?
- Can I Add Subscriptions Using Multiple Protocols to a Topic?
- Can a Topic Creator Change Subscription Protocols in a Topic?
- Can I Change a Subscription Endpoint for a Topic?
- Can I Delete a Published Message?
- Does SMN Ensure That Messages Are Received by Subscription Endpoints?
- Will a Subscriber Receive the Same Message Multiple Times?
- Why Do Subscribers Fail to Receive Messages After I Publish Messages to a Topic?
- What Can I Do When Pictures in an Email Message Cannot Be Displayed?
- Does SMN Always Use the Same Phone Number or Sender Name to Send SMS Messages?
- How Do I Obtain My Account ID?
- How Does a DingTalk, Internal DingTalk, Lark, or WeCom Chatbot Obtain Subscription Endpoints?
- Videos
More Documents
- Overview
- Getting Started
- Topic Management
- Logs
- Quotas
- Appendix
- Change History
- API Reference
User Guide (Paris Region)
- Overview
- Getting Started
- Topic Management
- Logs
- Quotas
- Appendix
- Change History
- API Reference (Paris Region)
- Overview
- Getting Started
- Topic Management
- Logs
- Quotas
- Appendix
- Change History
- API Reference (Kuala Lumpur Region)
User Guide (Ankara Region)
- Overview
- Getting Started
- Topic Management
- Quotas
- Appendix
- Change History
- API Reference (Ankara Region)
Configuring Alarm Rules
By configuring alarm rules for a topic, you can customize the monitored objects and notification policies to obtain the subscription push results of the topic in a timely manner.
- In the upper left corner of the page, click
and select the desired region and project.
- Click Service List in the upper left corner and select Cloud Eye.
- In the navigation pane on the left, choose Alarm Management > Alarm Rules.
- On the Alarm Rules page, modify an existing alarm rule or click Create Alarm Rule and create an alarm rule for a topic.
- After configuring the parameters, click Create.
Parent topic: Cloud Eye Monitoring
