- What's New
- Function Overview
- Getting Started
User Guide
- Topic Management
- Subscription Management
- Message Template Management
- SMN Operation Recording
- Cloud Eye Monitoring
- Logs
- Permissions Management
- Quotas
- Appendix
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- APIs
- Examples
- Public Parameters
- Out-of-Date APIs
- Appendix
- SDK Reference
- What Are the Advantages of SMN?
- What Protocols Does SMN Support?
- How Is SMN Billed?
- What Are the Requirements for an SMN Topic Name?
- How Many Topics Can I Create?
- How Many Subscriptions Can Be Added to a Topic?
- How Many Messages Can Be Published to a Topic?
- How Many Message Templates Can I Create?
- What Are the Limitations on SMS Messages?
- Can I Add Subscriptions Using Multiple Protocols to a Topic?
- Can a Topic Creator Change Subscription Protocols in a Topic?
- Can I Change a Subscription Endpoint for a Topic?
- Can I Delete a Published Message?
- Does SMN Ensure That Messages Are Received by Subscription Endpoints?
- Will a Subscriber Receive the Same Message Multiple Times?
- Why Do Subscribers Fail to Receive Messages After I Publish Messages to a Topic?
- What Can I Do When Pictures in an Email Message Cannot Be Displayed?
- Does SMN Always Use the Same Phone Number or Sender Name to Send SMS Messages?
- How Do I Obtain My Account ID?
- How Does a DingTalk, Internal DingTalk, Lark, or WeCom Chatbot Obtain Subscription Endpoints?
- Videos
More Documents
- Overview
- Getting Started
- Topic Management
- Logs
- Quotas
- Appendix
- Change History
- API Reference
User Guide (Paris Region)
- Overview
- Getting Started
- Topic Management
- Logs
- Quotas
- Appendix
- Change History
- API Reference (Paris Region)
- Overview
- Getting Started
- Topic Management
- Logs
- Quotas
- Appendix
- Change History
- API Reference (Kuala Lumpur Region)
User Guide (Ankara Region)
- Overview
- Getting Started
- Topic Management
- Quotas
- Appendix
- Change History
- API Reference (Ankara Region)
Metrics
Overview
This section describes metrics reported from SMN to Cloud Eye. You can use Cloud Eye to query the metrics and alarms generated for SMN.
Namespace
SYS.SMN
Metrics
Table 1 lists the metrics of SMN.
ID |
Name |
Description |
Value |
Monitored Object |
Monitoring Period (Raw Data) |
email_total_count |
Email Messages Published |
Total number of email messages published to your topic |
≥0 |
A single topic |
5 minutes |
email_success_rate |
Rate of Email Messages Delivered |
Rate of messages successfully delivered to email subscription endpoints Unit: percent |
0-100% |
A single topic |
5 minutes |
sms_total_count |
SMS Messages Published |
Total number of SMS messages that are attempted to be published to your topic |
≥0 |
A single topic |
5 minutes |
sms_success_rate |
Rate of SMS Messages Delivered |
Percentage of messages successfully delivered to SMS subscription endpoints Unit: percent |
0-100% |
A single topic |
5 minutes |
http_total_count |
HTTP(S) Messages Published |
Total number of HTTP or HTTPS messages published to your topics |
≥0 |
A single topic |
5 minutes |
http_2xx_count |
2xx Return Codes |
Number of 2xx return codes when messages are successfully delivered to HTTP or HTTPS subscription endpoints |
≥0 |
A single topic |
5 minutes |
http_4xx_count |
4xx Error Codes |
Number of 4xx error codes returned when SMN fails to deliver messages from your topics to HTTP or HTTPS subscription endpoints |
≥0 |
A single topic |
5 minutes |
http_5xx_count |
5xx Error Codes |
Number of 5xx error codes returned when subscribers fail to receive HTTP or HTTPS messages from SMN |
≥0 |
A single topic |
5 minutes |
http_success_rate |
Rate of HTTP(S) Messages Delivered |
Percentage of messages successfully delivered to HTTP and HTTPS subscription endpoints Unit: percent |
0-100% |
A single topic |
5 minutes |
message_published_count |
Messages Published to a Topic |
Number of messages published to a specific topic Unit: records |
≥0 |
A single topic |
5 minutes |
message_filtered_count |
Messages Filtered Out |
Number of messages that are rejected by the filtering policy configured for the subscription because message attributes are configured for messages published to a topic Unit: records |
≥0 |
A single topic |
5 minutes |
message_publish_size |
Size of Messages Published to a Topic |
Size of messages published to a specific topic Unit: byte |
≥0 |
A single topic |
5 minutes |
Dimension
Key |
Value |
topic_id |
Topic ID |
