Updated on 2026-06-17 GMT+08:00
Logs
You can use logs when you want to know the statuses of messages published to a topic. Protocols including SMS, FunctionGraph (function), email, HTTP, and HTTPS are supported. Before configuring logs, you need to interconnect SMN with Log Tank Service (LTS) and have created a log group and log stream to be associated. For details about how to configure and operate LTS, see Log Tank Service User Guide.
Configuring Cloud Logs
  1. Create a log group.
    1. Log in to the LTS console.
    2. In the navigation pane on the left, choose Log Management.
      The Log Management page appears.
    3. Click Create Log Group. In the displayed dialog box, enter a log group name.
    4. Click OK.
  2. Create a log stream.
    1. Locate the created log group and click its name.
    2. Click Create Log Stream. In the displayed dialog box, enter a name for the log stream.
    3. Click OK.
Configuring Message Transmission Logs
On the SMN console, configure logs.
  1. Set this parameter on the Create Topic page.
    1. Log in to the SMN console.
    2. In the navigation pane on the left, choose Topic Management > Topics.
      The Topics page appears.
    3. On the Topics page, click the name of the topic to be configured.
    4. On the displayed page, click the Message Transfer Logs tab and click Configure Access Logs.
      Figure 1 Logs
    5. Click Start Logging and select the log group and log stream that you have created on the LTS console.
      Figure 2 Configure Log
    6. Click OK.
Viewing Access Logs
You can view details about logs you configured.
Log format
{"message_id":"$message_id","project_id":"$project_id","topic_urn":"$topic_urn","subscriber_urn":"$subscriber_urn","protocol_name":"$protocol_name","endpoint":"$endpoint","status":"$status","http_code":$http_code,"create_time":"$create_time","send_time":"$send_time"}
The log format cannot be modified. Table 1 describes log fields.
Table 1 Parameters in a FunctionGraph (function) message
Type
message_id
String
Message ID
project_id
String
Project ID
topic_urn
String
Unique resource identifier of a topic
subscriber_urn
String
Unique resource identifier of a subscriber
protocol_name
String
The subscription protocol. (Different protocols indicate different types of endpoints to receive messages.) The following protocols are supported:
  • Email: The endpoints are email addresses.
  • SMS: The endpoints are phone numbers.
  • FunctionGraph: FunctionGraph (function) transmission protocol. The endpoint is a function.
  • FunctionStage: FunctionStage (workflow) transmission protocol. The endpoint is a function workflow.
  • HTTP and HTTPS: The endpoints are URLs.
endpoint
String
Message receiving endpoint
status
String
Message status. The options are as follows:
  • DELIVERED: The message has been delivered.
  • FAIL_DELIVERED: The message failed to be sent.
  • DELIVERING: The message is being sent.
http_code
Integer
HTTP return code. Only HTTP/HTTPS messages are supported.
create_time
String
Time when a message was created. The UTC time is in YYYY-MM-DDTHH:MM:SSZ format.
send_time
String
The time when the message was sent. The UTC time is in YYYY-MM-DDTHH:MM:SSZ format.
Example Log
{"message_id":"1ae49922602a42fc83acb9689a2eb5f4","project_id":"5a9f32e4f1ec4bbe9695ff9da51c2925","topic_urn":"urn:smn:regionid:5a9f32e4f1ec4bbe9695ff9da51c2925:demo","subscriber_urn":"urn:smn:regionid:5a9f32e4f1ec4bbe9695ff9da51c2925:demo:b55c3c6fa7cd471b9f24818d530a8740","protocol_name":"https","endpoint":"https://127.0.0.1:443/https","status":"DELIVERED","http_code":200,"create_time":"2022-11-01T00:00:00Z"}
Table 2 describes the fields in the log.
Table 2 Example values of fields in the log
Example Value
message_id
project_id
topic_urn
subscriber_urn
protocol_name
https
endpoint
status
DELIVERED
http_code
200
create_time
send_time
2022-11-01T00:00:10Z
