Help Center/ Simple Message Notification/ User Guide/ Message Template Management
Updated on 2025-10-29 GMT+08:00
Message templates contain fixed and changeable content and can be used to create messages more quickly. When you use a template to publish a message, you need to specify values for different variables in the template.
Message templates are identified by name, but you can create different templates with the same name as long as they are configured for different protocols. You must create a Default template with the same name as each custom template. The Default template is used when no specific template has been set for a given protocol. If a template is configured for a specific protocol, any subscriber who chose that protocol during subscription will receive messages using that specific template. If you create a custom template but do not create a default template with the same name, you cannot use the custom template to publish messages.
This section describes how to publish messages using a template.
Creating a Message Template
  2. Click on the upper left to select the desired region and project.
  3. Click . Select Management & Governance > Simple Message Notification.
    The SMN console is displayed.
  4. In the navigation pane on the left, choose Topic Management > Message Templates.
  5. In the upper right corner, click Create Message Template.
    The Create Message Template dialog box is displayed.
    Figure 1 Create Message Template
  6. Specify the template name, protocol, and content.
    Table 1 Parameters required for creating a message template
    Template Name
    Template name, which:
    • Contains only letters, digits, hyphens (-), and underscores (_) and must start with a letter or digit.
    • Can contain 1 to 64 characters.
    • Cannot be modified once the template is created.
    Protocol
    Endpoint protocol of the template, which cannot be changed once the template is created
    The protocol can be Default, SMS, Email, HTTP, HTTPS, or FunctionGraph (function).
    If you do not specify a protocol, Default is used.
    Content
    Template content
    Use {xxx} as the placeholder to create a template. When you use this template to publish messages, replace {xxx} with specific content. xxx must start with a letter or digit and can contain up to 21 characters, including only letters, digits, hyphens (-), periods (.), and underscores (_).
    The message template must meet the following requirements:
    • The template supports plain text only.
    • The template content cannot be left blank and its size cannot exceed 256 KB.
    • The template can contain up to 256 variables in total, but that includes redundant variables. For unique variables, there can be no more than 90.
    • When you publish messages using a template, the message content you specify for each variable cannot exceed 1 KB.
    For example, the template information is as follows:
    • Template Name: tem_001
    • Protocol: Default
    • Content: The Arts and Crafts Exposition will be held from {startdate} through {enddate}. We sincerely invite you to join us.
    Figure 2 Creating a message template
  7. Click OK.
    The template you created is displayed in the template list.
Modifying a Template
  1. On the Message Templates page, locate the template to be modified in the template list.
  2. Click Modify in the Operation column to change its content.
Deleting a Template
  1. On the Message Templates page, locate the template to be deleted in the template list.
  2. Click Delete in the Operation column.
