Testing SFS Turbo Performance
Fio is an open-source I/O tester. You can use fio to test the throughput and IOPS of SFS Turbo file systems.
Fio has been installed on the cloud server. You can download fio from its official website or GitHub.
Notes
- The test performance depends on the network bandwidth between the client and server, as well as the capacity of the file system.
- Perform the performance test when no services are running on SFS Turbo. Otherwise, the test performance may not meet the expectation as services occupy underlying resources.
Installing Fio
The following uses a Linux CentOS system as an example:
File System Performance Data
Table 1 lists the performance metrics of SFS Turbo file systems including IOPS and throughput.
Parameter |
20 MB/s/TiB |
40 MB/s/TiB |
125 MB/s/TiB |
250 MB/s/TiB |
500 MB/s/TiB |
1,000 MB/s/TiB |
Max. capacity |
1 PB |
1 PB |
1 PB |
1 PB |
1 PB |
1 PB |
Max. IOPS |
250,000 |
250,000 |
1 million |
1 million |
4 million |
4 million |
Max. throughput |
8 GB/s You can submit a service ticket before creating a file system to get up to 20 GB/s throughput. |
20 GB/s You can submit a service ticket before creating a file system to get up to 100 GB/s throughput. |
80 GB/s |
80 GB/s |
IOPS calculation formula |
IOPS = Min. (250,000, 600 x Capacity) Capacity unit: TB |
IOPS = Min. (250,000, 1,200 x Capacity) Capacity unit: TB |
IOPS = Min. (1,000,000, 6,000 x Capacity) Capacity unit: TB |
IOPS = Min. (1,000,000, 12,500 x Capacity) Capacity unit: TB |
IOPS = Min. (4,000,000, 25,000 x Capacity) Capacity unit: TB |
IOPS = Min. (4,000,000, 50,000 x Capacity) Capacity unit: TB |
Common Test Configuration Example
Test results provided in the following examples are obtained using a single ECS. You are advised to use multiple ECSs to test the SFS Turbo performance.
In the following example, an SFS Turbo Performance file system and an ECS with the following specifications are used for illustration.
Specifications: General computing-plus | c3.xlarge.4 | 4 vCPUs | 16 GB
Image: CentOS 7.5 64-bit
- fio command:
fio --randrepeat=1 --ioengine=libaio --name=test -output=output.log --direct=1 --filename=/mnt/nfs/test_fio --bs=4k --iodepth=128 --size=10240M --readwrite=rw --rwmixwrite=30 --fallocate=none
Variable /mnt/nfs/test_fio is the location of the file to be tested. The location must be specific to the file name, which is the test_fio file in the /mnt/nfs directory in this example. Set it based on the site requirements.
- fio result:
- fio command:
fio --randrepeat=1 --ioengine=libaio --name=test -output=output.log --direct=1 --filename=/mnt/nfs/test_fio --bs=4k --iodepth=128 --size=10240M --readwrite=rw --rwmixwrite=70 --fallocate=none
- fio result:
Sequential read IOPS
- fio command:
fio --ioengine=libaio --direct=1 --fallocate=none --time_based=1 --group_reporting=1 --name=iops_fio --directory=/mnt/sfs-turbo/ --rw=read --bs=4k --size=1G --iodepth=128 --runtime=120 --numjobs=10
Variable /mnt/sfs-turbo/ is the location of the file to be tested. The location must be specific to the file name. Set it to the actual file name.
- fio result:
Random read IOPS
- fio command:
fio --ioengine=libaio --direct=1 --fallocate=none --time_based=1 --group_reporting=1 --name=iops_fio --directory=/mnt/sfs-turbo/ --rw=randread --bs=4k --size=1G --iodepth=128 --runtime=120 --numjobs=10
- fio result:
Sequential write IOPS
- fio command:
fio --ioengine=libaio --direct=1 --fallocate=none --time_based=1 --group_reporting=1 --name=iops_fio --directory=/mnt/sfs-turbo/ --rw=write --bs=4k --size=1G --iodepth=128 --runtime=120 --numjobs=10
- fio result:
Random write IOPS
- fio command:
fio --ioengine=libaio --direct=1 --fallocate=none --time_based=1 --group_reporting=1 --name=iops_fio --directory=/mnt/sfs-turbo/ --rw=randwrite --bs=4k --size=1G --iodepth=128 --runtime=120 --numjobs=10
- fio result:
Sequential read bandwidth
- fio command:
fio --randrepeat=1 --ioengine=libaio --name=test -output=output.log --direct=1 --filename=/mnt/sfs-turbo/test_fio --bs=1M --iodepth=128 --size=10240M --readwrite=read --fallocate=none
Variable /mnt/sfs-turbo/test_fio is the location of the file to be tested. The location must be specific to the file name, which is the test_fio file in the /mnt/sfs-turbo directory in this example. Set it based on the site requirements.
- fio result:
Random read bandwidth
- fio command:
fio --ioengine=libaio --direct=1 --fallocate=none --time_based=1 --group_reporting=1 --name=iops_fio --directory=/mnt/sfs-turbo/ --rw=randread --bs=1M --size=10G --iodepth=128 --runtime=120 --numjobs=1
- fio result:
Sequential write bandwidth
- fio command:
fio --ioengine=libaio --direct=1 --fallocate=none --time_based=1 --group_reporting=1 --name=iops_fio --directory=/mnt/sfs-turbo/ --rw=write --bs=1M --size=10G --iodepth=128 --runtime=120 --numjobs=1
- fio result:
Random write bandwidth
- fio command:
fio --ioengine=libaio --direct=1 --fallocate=none --time_based=1 --group_reporting=1 --name=iops_fio --directory=/mnt/sfs-turbo/ --rw=randwrite --bs=1M --size=10G --iodepth=128 --runtime=120 --numjobs=1
- fio result:
