Updated on 2025-09-17 GMT+08:00
Viewing an SFS Turbo File System
You can search for file systems by file system name, status or other properties, and view their basic information.
Viewing details of SFS Turbo file systems depends on the VPC service. Ensure that the required role or policy has been configured.
The permissions of the SFS Turbo ReadOnlyAccess policy already include the permissions of VPC ReadOnlyAccess, which are required for querying file system details. An IAM user assigned the SFS Turbo ReadOnlyAccess policy does not need to have the VPC ReadOnlyAccess policy assigned explicitly.
  1. Log in to the SFS Turbo console.
  2. In the file system list, view the file systems you have created. Table 1 describes the file system parameters.
    Table 1 File system parameters
    Name
    Name of a file system, for example, sfs-turbo-name001
    Status
    There are the following file system statuses: Available, Unavailable, Frozen, Creating, Deleting, Abnormal, Creation failed, Expanding
    AZ
    Availability zone where a file system resides
    Type
    File system type
    Protocol Type
    File system protocol, which can be NFS or SMB
    Used Capacity (GB)
    File system space already used for data storage
    This information is refreshed every 15 minutes.
    Maximum Capacity (GB)
    Maximum capacity of the file system
    Encryption
    Encryption status of a file system. The value can be Yes or No.
    Enterprise Project
    Enterprise project to which a file system belongs
    Shared Path
    File system address
    Billing Mode
    Billing mode of a file system. The value can be Pay-per-use or Yearly/Monthly. In addition, the creation time is displayed for a pay-per-use file system, and the expiration time is displayed for a yearly/monthly file system.
    Operation
    Provides the Expand Capacity, Delete, View Metric, Create Backup, Renew, and Unsubscribe buttons.
    You can renew or unsubscribe from a yearly/monthly SFS Turbo file system about 1 or 2 minutes after it has been created.
  3. Click the name of a file system to view its basic information.
    On the Basic Info tab, you can click View details to the right of Client IP Addresses to check the IP addresses of the clients. In addition, you can modify the name, cold data eviction duration, and security group.
    Figure 1 Details of an SFS Turbo file system
  4. (Optional) Search for specific SFS Turbo file systems by name, ID, status, AZ, type, protocol type, used capacity, total capacity, encryption, enterprise project, KMS key ID, shared path, or billing mode.
