Data Migration Overview
By default, an SFS Turbo file system can only be accessed by ECSs or CCE containers in the same VPC as the file system. To access an SFS Turbo file system from an on-premises data center or a different VPC, you need to establish network connections using Direct Connect, VPN, or VPC peering connections.
- To access from on premises or another cloud, use Direct Connect or VPN.
- To access from a different VPC using the same account in the same region, use VPC peering.
- To access using a different account in the same region, use VPC peering.
- To access from a different region, use Cloud Connect.
This section mainly introduces how to migrate data from the local NAS storage to SFS Turbo through direct file system mount to an ECS that can access the Internet. There are two scenarios:
- Mount and access the SFS Turbo file system.
- If the connection cannot be established through file system mounting, migrate data through the ECS over the Internet.
