Enterprise Website/App Background
Context
For I/O-intensive website services, SFS Turbo can provide shared website source code directories and storage for multiple web servers, enabling low-latency and high-IOPS concurrent share access. Features of such services are as follows:
- Massive small files: Static website files need to be stored, including HTML files, JSON files, and static images.
- Intensive read I/Os: Heavy read of small files, less data writes
- Concurrent access: Multiple web servers access an SFS Turbo background for high availability of website services.
Configuration Process
- Sort out the website files.
- Log in to the SFS Turbo console. Create an SFS Turbo file system to store website files.
- Log in to the cloud server that functions as the compute node and mount the file system.
- On the head node, upload the files to the file system.
- Start the web server.
- A VPC has been created.
- Cloud servers that function as the head node and compute node have been created, and are in the created VPC. To upload on-premises website files to the SFS Turbo file system, see Migrating Local Data to SFS Turbo Using Direct Connect.
- SFS Turbo has been enabled.
Example Configuration
- In the upper right corner of the page, click Create File System.
- On the Create File System page, configure parameters as instructed.
- After the configuration is complete, click Create Now.
To mount a file system to Linux ECSs, see Mounting an SFS Turbo File System to Linux ECSs. To mount a file system to Windows ECSs, see Mounting an SFS Turbo File System to Windows ECSs.
- Log in to the head node and upload the files to the file system.
