Supported SFS Turbo Operations
Updated on 2024-11-04 GMT+08:00
Cloud Trace Service (CTS) records operations performed on SFS Turbo file systems, facilitating query, audit, and backtracking.
You have enabled CTS and the tracker is normal. For details about how to enable CTS, see Enabling CTS in the Cloud Trace Service Getting Started.
Operations
Table 1 SFS Turbo operations traced by CTS
Operation
Resource Type
Trace
Creating a file system
sfs_turbo
createShare
Deleting a file system
sfs_turbo
deleteShare
Querying Traces
  1. Log in to the console.
  2. Click in the upper left corner and select a region.
  3. Choose Management & Governance > Cloud Trace Service.
    The Cloud Trace Service page is displayed.
  4. In the navigation pane on the left, choose Trace List.
  5. On the trace list page, set Trace Source, Resource Type, and Search By, and click Query to query the specified traces.
    For details about other operations, see section "Querying Real-Time Traces" in the Cloud Trace Service User Guide.
Disabling or Enabling a Tracker
The following procedure describes how to disable a tracker on the CTS console. After the tracker is disabled, CTS will stop recording operations, but you can still view existing operation records.
  2. Click in the upper left corner and select a region and project.
  4. Choose Tracker List in the left navigation pane.
  5. Find the tracker you want to disable, and click Disable in the Operation column.
  6. Click OK.
  7. After the tracker is disabled, the available operation changes from Disable to Enable. To re-enable the tracker, click Enable and then click OK. CTS will start recording operations again.
