SFS Turbo Metrics
Function
This section describes the SFS Turbo metrics reported to Cloud Eye as well as their namespaces and dimensions. You can use the Cloud Eye console or APIs provided by Cloud Eye to query the SFS Turbo metrics and alarms.
- Cloud Eye can monitor dimensions nested to a maximum depth of four levels (levels 0 to 3). 3 is the deepest level.
- Monitoring is currently not supported for SMB file systems.
Namespace
SYS.EFS
Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Unit |
Conversion Rule |
Dimension |
Monitoring Period (Raw Data) |
client_connections |
Client Connections |
Number of client connections
Only active client connections are counted. A network connection is automatically disconnected when the client has no I/Os for a long time and is automatically re-established when there are I/Os. |
≥ 0 |
count |
N/A |
efs_instance_id |
1 minute |
data_read_io_bytes |
Read Bandwidth |
Data read I/O load |
≥ 0 |
bytes/s |
1024 (IEC) |
efs_instance_id |
1 minute |
data_write_io_bytes |
Write Bandwidth |
Data write I/O load |
≥ 0 |
bytes/s |
1024 (IEC) |
efs_instance_id |
1 minute |
metadata_io_bytes |
Metadata Read and Write Bandwidth |
Metadata read and write I/O load |
≥ 0 |
bytes/s |
1024 (IEC) |
efs_instance_id |
1 minute |
total_io_bytes |
Total Bandwidth |
Total I/O load |
≥ 0 |
bytes/s |
1024 (IEC) |
efs_instance_id |
1 minute |
iops |
IOPS |
I/O operations per unit time |
≥ 0 |
count |
N/A |
efs_instance_id |
1 minute |
used_capacity |
Used Capacity |
Used capacity of a file system |
≥ 0 |
bytes |
1024 (IEC) |
efs_instance_id |
1 minute |
used_capacity_percent |
Capacity Usage |
Percentage of used capacity in the total capacity |
0–100 |
N/A |
efs_instance_id |
1 minute |
used_inode |
Used inodes |
Number of inodes used in a file system |
≥ 1 |
count |
N/A |
efs_instance_id |
1 minute |
used_inode_percent |
Inode Usage |
Percentage of used inodes to total inodes in a file system |
0–100 |
N/A |
efs_instance_id |
1 minute |
Dimension
Key |
Value |
efs_instance_id |
Instance |
Viewing Monitoring Statistics
- View the monitoring graphs using either of the following methods.
- Method 1: Log in to the SFS Turbo console. In the file system list, locate the desired file system and click Monitoring in the Operation column.
- Method 2: Log in to the Cloud Eye console. Choose Cloud Service Monitoring > Scalable File Service Turbo EFS > Resources. In the file system list, locate the desired file system and click View Metric in the Operation column.
- View the SFS Turbo file system monitoring data by metric or monitored duration.
Figure 1 shows the monitoring graphs. For more information about Cloud Eye, see the Cloud Eye User Guide.
