Creating an IAM User and Granting SFS Turbo Permissions
This section describes how to use IAM to implement fine-grained permissions control for your SFS Turbo resources. With IAM, you can:
- Create IAM users for employees based on your enterprise's organizational structure. Each IAM user will have their own security credentials for accessing SFS Turbo resources.
- Grant users only the permissions required to perform a given task based on their job responsibilities.
If your HUAWEI ID does not require individual IAM users, skip this section.
This section describes the procedure for granting user permissions. Figure 1 shows the process flow.
Before granting permissions to user groups, learn about SFS Turbo system-defined permissions. For the permissions of other services, see System Permissions.
Process Flow
- Create a user group and assign permissions to it.
Create a user group on the IAM console and assign the SFS Turbo ReadOnlyAccess permissions to the group.
- Create a user and add it to a user group.
Create a user on the IAM console and add the user to the group created in 1.
- Log in and verify permissions.
In the authorized region, perform the following operations:
- Choose Service List > Scalable File Service Turbo. On the SFS Turbo console, click Create File System in the upper right corner. If a message appears indicating that you have insufficient permissions to perform the operation, the SFS Turbo ReadOnlyAccess permissions are in effect.
- Choose another service from Service List. If a message appears indicating that you have insufficient permissions to access the service, the SFS Turbo ReadOnlyAccess permissions are in effect.
