- What's New
- Function Overview
- Product Bulletin
- Billing
- Getting Started
- User Guide
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
API
- Lifecycle Management
- Connection Management
- Tag Management
- Name Management
- File System Management
Storage Interworking Management
- Adding a Backend Target
- Querying Backend Targets
- Obtaining Details About a Backend Target
- Deleting a Backend Target
- Updating the Properties of a Storage Backend
- Updating the Auto Synchronization Policy of a Storage Backend
- Creating an Import or Export Task
- Querying Details About an Import or Export Task
- Listing Import and Export Tasks
- Deleting an Import or Export Task
- Updating a File System
- Directory Management
Permissions Management
- Creating a Permission Rule
- Querying Permission Rules of a File System
- Querying a Permission Rule of a File System
- Modifying a Permission Rule
- Deleting a Permissions Rule
- Creating and Binding the LDAP Configuration
- Querying the LDAP Configuration
- Modifying the LDAP Configuration
- Deleting the LDAP Configuration
- Task Management
- Common Parameters
- Appendix
- SDK Reference
- SFS Turbo Concepts
- SFS Turbo Specifications
- SFS Turbo Billing
SFS Turbo Mount
- What Can I Do If Data of My SFS Turbo File System Is Not the Same When Accessed from Two Client Servers?
- Can I Mount an SFS Turbo File System Across Regions?
- Can I Mount an SFS Turbo File System Across Accounts?
- How Many Cloud Servers Can I Mount an SFS Turbo File System To?
- How Do I Mount a File System to a Linux ECS as a Non-root User
- What Can I Do If Mounting a Subdirectory of a File System Failed?
- SFS Turbo Access
- SFS Turbo Capacity Expansion
- SFS Turbo Deletion
- SFS Turbo Migration
- SFS Turbo Performance
- Does the Security Group of a VPC Affect the Use of SFS Turbo?
- What Resources Does SFS Turbo Occupy?
- How Do I Check Whether an SFS Turbo File System Is Available on a Linux Server?
- Can I Upgrade an SFS Turbo File System from the Standard Type to the Performance Type?
- Does SFS Turbo File Systems Support Multi-AZ Deployment?
Troubleshooting
- Mounting a File System Timed Out
- Mounting a File System Failed
- File System Performance Was Poor
- Creating an SFS Turbo File System Failed
- File System Automatically Unmounted
- A Client Server Failed to Access a File System
- Abnormal File System Status
- Data Fails to Be Written into a File System Mounted to ECSs Running Different Types of Operating Systems
- Writing to a File System Failed
- Error Message "wrong fs type, bad option" Was Displayed During File System Mounting
Show all
Unmounting an SFS Turbo File System
If an SFS Turbo file system is no longer required, you can unmount it and then delete it.
Stop the process and read/write operations before you unmount a file system.
Linux OS
- Log in to the ECS.
- Run the following command:
umount <Local path>
Variable <Local path> is an ECS local directory where the file system is mounted, for example, /local_path.
Before running the umount command, stop all read and write operations related to the SFS Turbo file system and exit from the local path. Or, the unmounting will fail.
