Updated on 2025-12-10 GMT+08:00
Deleting a General-Purpose File System
Data in a deleted general-purpose file system cannot be recovered. Ensure that files in a general-purpose file system have been properly stored or backed up before you delete the file system.
You are advised to unmount the general-purpose file system before deleting it. For how to unmount general-purpose file systems, see Unmounting a General-Purpose File System.
  1. Log in to the SFS console.
  2. In the general-purpose file system list, find the file system you want to delete and click Delete in the Operation column.
  3. In the displayed dialog box shown in Figure 1, confirm the information, enter DELETE in the text box, and click OK.
    A general-purpose file system can only be deleted when the file system's used capacity and the number of files in the file system are both zero.
    Figure 1 Deleting a general-purpose file system
  4. Check whether the general-purpose file system is successfully deleted.
    If the file system disappears from the file system list, the deletion is successful. If you can still see it in the list, the deletion fails. In this case, submit a service ticket.
