Viewing a File System
You can search for a file system by name keyword, status, or other properties, and view the file system basic information.
  - Viewing details of SFS Turbo file systems depends on the VPC service. Ensure that the required role or policy has been configured.
The permissions of the SFS Turbo ReadOnlyAccess policy already include the permissions of VPC ReadOnlyAccess, which are required for querying file system details. An IAM user assigned the SFS Turbo ReadOnlyAccess policy does not need to have the VPC ReadOnlyAccess policy assigned explicitly.
 - Viewing details of general purpose file systems depends on the VPC service. Ensure that the required role or policy has been configured.
The permissions of the SFS3 ReadOnlyAccess policy already include the permissions of VPC ReadOnlyAccess, which are required for querying general purpose file system details. An IAM user assigned the SFS3 ReadOnlyAccess policy does not need to have the VPC ReadOnlyAccess policy assigned explicitly.
- Log in to the SFS console.
 - In the file system list, view the file systems you have created. Table 1 describes the file system parameters.
Table 1 Parameter description Parameter
Name
Name of the file system, for example, sfs-name-001
AZ
Availability zone where the file system resides
Status
Possible values are Available, Unavailable, Frozen, Creating, Deleting.
Type
File system type
Protocol Type
File system protocol, which can be NFS or CIFS
Used Capacity (GB)
File system space already used for data storage
NOTE:This information is refreshed every 15 minutes. The used capacity will not be displayed if less than 1 MB of an SFS Capacity-Oriented file system is used.
Maximum Capacity (GB)
Maximum capacity of the file system
Uploaded Files (Count)
Number of files that have been uploaded to the file system
NOTE:This field is displayed for general purpose file systems.
Standard Storage Used Capacity
Total standard storage used in the general purpose file system
Uploaded Standard Files (Count)
Total number of files that use standard storage in the general purpose file system
Warm Storage Used Capacity
Total infrequent access storage used in the general purpose file system
Uploaded Warm Files (Count)
Total number of files that use infrequent access storage in the general purpose file system
Encrypted
Encryption status of the file system. The value can be Yes or No.
Enterprise Project
Enterprise project to which the file system belongs
Mount Point
File system mount point. The format of an NFS file system is File system domain name:/Path or File system IP address:/. The format of a CIFS file system is \\File system domain name\Path.
NOTE:If the mount point is too long to display completely, adjust the column width.
Tags
Tag information of a general purpose file system
Created
Time when the file system was created
Operation
For an SFS Capacity-Oriented file system, operations include resizing, deletion, and monitoring metric viewing.
For an SFS Turbo file system, operations include capacity expansion, deletion, monitoring metric viewing, subscription renewal, and unsubscription.
For a general purpose file system, operations include limits management and deletion.
 - Click the name of a file system to view its basic information.
    Figure 1 Details of an SFS Turbo file system
    Figure 2 Details of a general purpose file system
    Figure 3 File system information
     - (Optional) Search for the specified file system by properties, such as file system name.
