Testing SFS Turbo Performance
Fio is an open-source I/O tester. You can use fio to test the throughput and IOPS of SFS Turbo file systems.
Fio has been installed on the cloud server. You can download fio from its official website or GitHub.
Notes
- The test performance depends on the network bandwidth between the client and server, as well as the capacity of the file system.
- Perform the performance test when no services are running on SFS Turbo. Otherwise, the test performance may not meet the expectation due to the underlying resources occupied by services.
Installing Fio
The following uses a Linux CentOS system as an example:
Common Test Configuration Example
Test results provided in the following examples are obtained using a single ECS. To reach the expected performance of SFS file systems, use multiple ECSs in the test.
In the following example, an SFS Turbo Performance file system and an ECS with the following specifications are used for illustration.
Specifications: General computing-plus | c3.xlarge.4 | 4 vCPUs | 16 GB
Image: CentOS 7.5 64-bit
- fio command:
fio --randrepeat=1 --ioengine=libaio --name=test -output=output.log --direct=1 --filename=/mnt/nfs/test_fio --bs=4k --iodepth=128 --size=10240M --readwrite=rw --rwmixwrite=30 --fallocate=none
/mnt/nfs/test_fio indicates the location of the file to be tested. The location must be specific to the file name, which is the test_fio file in the /mnt/nfs directory in this example. Set it based on the site requirements.
- fio result:
- fio command:
fio --randrepeat=1 --ioengine=libaio --name=test -output=output.log --direct=1 --filename=/mnt/nfs/test_fio --bs=4k --iodepth=128 --size=10240M --readwrite=rw --rwmixwrite=70 --fallocate=none
- fio result:
Sequential read IOPS
- fio command:
fio --ioengine=libaio --direct=1 --fallocate=none --time_based=1 --group_reporting=1 --name=iops_fio --directory=/mnt/sfs-turbo/ --rw=read --bs=4k --size=1G --iodepth=128 --runtime=120 --numjobs=10
Variable /mnt/sfs-turbo/ is the local path where the file to be tested is stored. Set it to the actual file name.
- fio result:
Random read IOPS
- fio command:
fio --ioengine=libaio --direct=1 --fallocate=none --time_based=1 --group_reporting=1 --name=iops_fio --directory=/mnt/sfs-turbo/ --rw=randread --bs=4k --size=1G --iodepth=128 --runtime=120 --numjobs=10
- fio result:
Sequential write IOPS
- fio command:
fio --ioengine=libaio --direct=1 --fallocate=none --time_based=1 --group_reporting=1 --name=iops_fio --directory=/mnt/sfs-turbo/ --rw=write --bs=4k --size=1G --iodepth=128 --runtime=120 --numjobs=10
- fio result:
Random write IOPS
- fio command:
fio --ioengine=libaio --direct=1 --fallocate=none --time_based=1 --group_reporting=1 --name=iops_fio --directory=/mnt/sfs-turbo/ --rw=randwrite --bs=4k --size=1G --iodepth=128 --runtime=120 --numjobs=10
- fio result:
Sequential read bandwidth
- fio command:
fio --randrepeat=1 --ioengine=libaio --name=test -output=output.log --direct=1 --filename=/mnt/sfs-turbo/test_fio --bs=1M --iodepth=128 --size=10240M --readwrite=read --fallocate=none
/mnt/sfs-turbo/test_fio indicates the location of the file to be tested. The location must be specific to the file name, which is the test_fio file in the /mnt/sfs-turbo directory in this example. Set it based on the site requirements.
- fio result:
Random read bandwidth
- fio command:
fio --ioengine=libaio --direct=1 --fallocate=none --time_based=1 --group_reporting=1 --name=iops_fio --directory=/mnt/sfs-turbo/ --rw=randread --bs=1M --size=10G --iodepth=128 --runtime=120 --numjobs=1
- fio result:
Sequential write bandwidth
- fio command:
fio --ioengine=libaio --direct=1 --fallocate=none --time_based=1 --group_reporting=1 --name=iops_fio --directory=/mnt/sfs-turbo/ --rw=write --bs=1M --size=10G --iodepth=128 --runtime=120 --numjobs=1
- fio result:
Random write bandwidth
- fio command:
fio --ioengine=libaio --direct=1 --fallocate=none --time_based=1 --group_reporting=1 --name=iops_fio --directory=/mnt/sfs-turbo/ --rw=randwrite --bs=1M --size=10G --iodepth=128 --runtime=120 --numjobs=1
- fio result:
