SFS Turbo Metrics
Updated on 2024-11-29 GMT+08:00
Function
This section describes metrics reported by SFS Turbo to Cloud Eye as well as their namespaces and dimensions. You can use the console or APIs provided by Cloud Eye to query the metrics generated for SFS Turbo.
Namespace
SYS.EFS
Metrics
Table 1 SFS Turbo metrics
Metric ID
Metric Name
Value Range
Monitored Object
Monitoring Period (Raw Data)
client_connections
Client Connections
Number of client connections
Only active client connections are counted.
A network connection is automatically disconnected when the client has no I/Os for a long time and is automatically re-established when there are I/Os.
≥ 0
SFS Turbo file system
1 minute
data_read_io_bytes
Read Bandwidth
Data read I/O load
Unit: byte/s
≥ 0 bytes/s
1 minute
data_write_io_bytes
Write Bandwidth
Data write I/O load
Unit: byte/s
≥ 0 bytes/s
1 minute
metadata_io_bytes
Metadata Read and Write Bandwidth
Metadata read and write I/O load
Unit: byte/s
≥ 0 bytes/s
1 minute
total_io_bytes
Total Bandwidth
Total I/O load
Unit: byte/s
≥ 0 bytes/s
1 minute
iops
IOPS
I/O operations per unit time
≥ 0
1 minute
used_capacity
Used Capacity
Used capacity of a file system
Unit: byte
≥ 0 bytes
1 minute
used_capacity_percent
Capacity Usage
Percentage of used capacity in the total capacity
Unit: percent
0% to 100%
1 minute
used_inode
Used inodes
Number of inodes used in a file system
≥ 1
1 minute
used_inode_percent
Inode Usage
Percentage of used inodes to total inodes in a file system Unit: percent
0% to 100%
1 minute
Dimension
Key
Value
efs_instance_id
Instance
Viewing Monitoring Statistics
  2. View the monitoring graphs using either of the following methods.
    • Method 1: Choose Storage > Scalable File Service. In the file system list, click Monitoring in the Operation column of the desired file system.
    • Method 2: Choose Management & Governance > Cloud Eye > Cloud Service Monitoring > SFS Turbo EFS. In the file system list, click View Metric in the Operation column of the desired file system.
  3. View the SFS Turbo file system monitoring data by metric or monitored duration.
    For more information, see the Cloud Eye User Guide.
    Figure 1 SFS Turbo monitoring graphs
