Updated on 2026-06-29 GMT+08:00
SFS Metrics
Function
This section describes the SFS metrics reported to Cloud Eye as well as their namespaces and dimensions. You can use the Cloud Eye console or APIs provided by Cloud Eye to query the SFS metrics and alarms.
Cloud Eye can monitor dimensions nested to a maximum depth of four levels (levels 0 to 3). 3 is the deepest level.
Namespace
SYS.SFS
Metrics
Table 1 General-Purpose File System metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Dimension
Monitoring Period (Raw Data)
capacity_standard
Capacity Class Storage Usage
Storage space used by standard storage
≥ 0
bytes
1024 (IEC)
bucket_name
30 minutes
capacity_infrequentaccess
Infrequent-Access Class Storage Usage
Storage space used by infrequent access storage
≥ 0
bytes
1024 (IEC)
bucket_name
30 minutes
read_bandwidth
File system read bandwidth
Read bandwidth of a file system within a monitoring period
≥ 0
bytes/s
1024 (IEC)
share_id
4 minutes
write_bandwidth
File system write bandwidth
Write bandwidth of a file system within a monitoring period
≥ 0
bytes/s
1024 (IEC)
share_id
4 minutes
read_tps
File system read TPS
Number of read operations of a file system within a monitoring period
≥ 0
count
N/A
bucket_name
4 minutes
write_tps
File system write TPS
Number of write operations of a file system within a monitoring period
≥ 0
count
N/A
bucket_name
4 minutes
General-purpose file system capacity cannot be monitored using the used_capacity metric.
Monitoring data of general-purpose file systems are only displayed when there are service accesses.
Dimension
Key
Value
share_id
bucket_name
Viewing Monitoring Statistics
  1. Log in to the Cloud Eye console.
  2. Choose Cloud Service Monitoring > Scalable File Service SFS.
  3. Click the name in the ID column to go to the resource instance page.
  4. View the SFS file system monitoring data by metric or monitored duration.
    Figure 1 shows the monitoring graphs. For more information about Cloud Eye, see the Cloud Eye User Guide.
    Figure 1 Monitoring graphs of a general-purpose file system
