- What's New
- Function Overview
Billing
- Billing Overview
- Billing Modes
- Billed Items
- Billing Examples
- Billing Mode Changes
- Renewing Subscriptions
- Bills
- Arrears
- Billing Termination
- Cost Management
Billing FAQ
- How Do I Purchase SFS?
- How Do I Renew the Service?
- How Do I Check Whether the Subscriber Is in Arrears?
- Can I Purchase SFS Capacity-Oriented Resource Packages When I Still Have Valid Ones in Use?
- How Do I Check the Usage of an SFS Capacity-Oriented Resource Package?
- How Do I Adjust the Size of an SFS Capacity-Oriented Resource Package?
- Do SFS Capacity-Oriented and SFS Turbo Share One Resource Package?
- Getting Started
- User Guide
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- Calling General Purpose File System APIs
- Getting Started (SFS Capacity-Oriented)
- Getting Started with SFS Turbo
- Getting Started with General Purpose File System
SFS Capacity-Oriented APIs
- API Version Queries
- File Systems
- File System Access Rules
- Quota Management
- Expansion and Shrinking
Tag Management
- Adding a Tag to a Shared File System
- Deleting a Tag from a Shared File System
- Querying Tags of a Shared File System
- Querying Tags of All File Systems of a Tenant
- Batch Adding Tags to a Shared File System
- Batch Deleting Tags from a Shared File System
- Querying Shared File Systems by Tag
- Querying the Number of Shared File Systems by Tag
- AZ
SFS Turbo APIs
- Lifecycle Management
- Connection Management
- Tag Management
- Name Management
- File System Management
Storage Interworking Management
- Adding a Backend Target
- Querying Backend Targets
- Obtaining Details About a Backend Target
- Deleting a Backend Target
- Updating the Properties of a Storage Backend
- Updating the Auto Synchronization Policy of a Storage Backend
- Creating an Import or Export Task
- Querying Details About an Import or Export Task
- Listing Import and Export Tasks
- Deleting an Import or Export Task
- Updating a File System
- Directory Management
Permissions Management
- Creating a Permission Rule
- Querying Permission Rules of a File System
- Querying a Permission Rule of a File System
- Modifying a Permission Rule
- Deleting a Permissions Rule
- Creating and Binding the LDAP Configuration
- Querying the LDAP Configuration
- Modifying the LDAP Configuration
- Deleting the LDAP Configuration
- Task Management
- General Purpose File System APIs
- Common Parameters
- Appendix
- SDK Reference
Troubleshooting
- Mounting a File System Times Out
- Mounting a File System Fails
- File System Performance Is Poor
- Failed to Create an SFS Turbo File System
- A File System Is Automatically Disconnected from the Server
- A Server Fails to Access a File System
- The File System Is Abnormal
- Data Fails to Be Written into a File System Mounted to ECSs Running Different Types of Operating Systems
- Failed to Mount an NFS File System to a Windows IIS Server
- Writing to a File System Fails
- Error Message "wrong fs type, bad option" Is Displayed During File System Mounting
- Failed to Access the Shared Folder in Windows
- Concepts
- Specifications
- Restrictions
- Networks
Billing
- How Do I Access a File System from a Server?
- How Do I Check Whether a File System on a Linux Server Is Available?
- What Resources Does SFS Occupy?
- Why Is the Capacity Displayed as 10P After I Mount My SFS Capacity-Oriented File System?
- Why the Capacity Is Displayed as 250TB After I Mount My General Purpose File System?
- How Can I Migrate Data Between SFS and OBS?
- Can a File System Be Accessed Across Multiple AZs?
- Can I Upgrade an SFS Capacity-Oriented File System to an SFS Turbo File System?
- Can I Upgrade an SFS Turbo File System from Standard to Standard-Enhanced?
- How Can I Migrate Data Between SFS and EVS?
- Can I Directly Access SFS from On-premises Devices?
- How Do I Delete .nfs Files?
- Why My File System Used Space Increases After I Migrate from SFS Capacity-Oriented to SFS Turbo?
- How Can I Improve the Copy and Delete Efficiency with an SFS Turbo File System?
- How Do Second- and Third-level Directory Permissions of an SFS Turbo File System Be Inherited?
- How Do I Deploy SFS Turbo on CCE?
- Videos
More Documents
- User Guide (ME-Abu Dhabi Region)
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris Region)
- Introduction
- Getting Started
- Management
- Typical Applications
Troubleshooting
- Concepts
- Specifications
- Restrictions
- Networks
- Other Operations
- Change History
- API Reference (Paris Region)
- User Guide (Kuala Lumpur Region)
- API Reference (Kuala Lumpur Region)
- Glossary
Encryption
Creating an Encrypted File System
To use the file system encryption function, you need to authorize SFS Capacity-Oriented to access KMS when creating an SFS Capacity-Oriented file system. If you have the Security Administrator rights, grant SFS the permissions to access KMS directly. Otherwise, you need to contact the system administrator to obtain the "Security Administrator" rights first..
For SFS Turbo file systems, no authorization is required.
You can create a file system that is encrypted or not, but you cannot change the encryption settings of an existing file system.
For details about how to create an encrypted file system, see Create a File System.
Unmounting an Encrypted File System
If the custom key used by the encrypted file system is disabled or scheduled for deletion, the file system can only be used within a certain period of time (30s by default). Exercise caution in this case.
For details about how to unmount the file system, see Unmount a File System.
