- What's New
- Function Overview
Billing
- Billing Overview
- Billing Modes
- Billed Items
- Billing Examples
- Billing Mode Changes
- Renewing Subscriptions
- Bills
- Arrears
- Billing Termination
- Cost Management
Billing FAQ
- How Do I Purchase SFS?
- How Do I Renew the Service?
- How Do I Check Whether the Subscriber Is in Arrears?
- Can I Purchase SFS Capacity-Oriented Resource Packages When I Still Have Valid Ones in Use?
- How Do I Check the Usage of an SFS Capacity-Oriented Resource Package?
- How Do I Adjust the Size of an SFS Capacity-Oriented Resource Package?
- Do SFS Capacity-Oriented and SFS Turbo Share One Resource Package?
- Getting Started
- User Guide
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- Calling General Purpose File System APIs
- Getting Started (SFS Capacity-Oriented)
- Getting Started with SFS Turbo
- Getting Started with General Purpose File System
SFS Capacity-Oriented APIs
- API Version Queries
- File Systems
- File System Access Rules
- Quota Management
- Expansion and Shrinking
Tag Management
- Adding a Tag to a Shared File System
- Deleting a Tag from a Shared File System
- Querying Tags of a Shared File System
- Querying Tags of All File Systems of a Tenant
- Batch Adding Tags to a Shared File System
- Batch Deleting Tags from a Shared File System
- Querying Shared File Systems by Tag
- Querying the Number of Shared File Systems by Tag
- AZ
SFS Turbo APIs
- Lifecycle Management
- Connection Management
- Tag Management
- Name Management
- File System Management
Storage Interworking Management
- Adding a Backend Target
- Querying Backend Targets
- Obtaining Details About a Backend Target
- Deleting a Backend Target
- Updating the Properties of a Storage Backend
- Updating the Auto Synchronization Policy of a Storage Backend
- Creating an Import or Export Task
- Querying Details About an Import or Export Task
- Listing Import and Export Tasks
- Deleting an Import or Export Task
- Updating a File System
- Directory Management
Permissions Management
- Creating a Permission Rule
- Querying Permission Rules of a File System
- Querying a Permission Rule of a File System
- Modifying a Permission Rule
- Deleting a Permissions Rule
- Creating and Binding the LDAP Configuration
- Querying the LDAP Configuration
- Modifying the LDAP Configuration
- Deleting the LDAP Configuration
- Task Management
- General Purpose File System APIs
- Common Parameters
- Appendix
- SDK Reference
Troubleshooting
- Mounting a File System Times Out
- Mounting a File System Fails
- File System Performance Is Poor
- Failed to Create an SFS Turbo File System
- A File System Is Automatically Disconnected from the Server
- A Server Fails to Access a File System
- The File System Is Abnormal
- Data Fails to Be Written into a File System Mounted to ECSs Running Different Types of Operating Systems
- Failed to Mount an NFS File System to a Windows IIS Server
- Writing to a File System Fails
- Error Message "wrong fs type, bad option" Is Displayed During File System Mounting
- Failed to Access the Shared Folder in Windows
- Concepts
- Specifications
- Restrictions
- Networks
Billing
- How Do I Access a File System from a Server?
- How Do I Check Whether a File System on a Linux Server Is Available?
- What Resources Does SFS Occupy?
- Why Is the Capacity Displayed as 10P After I Mount My SFS Capacity-Oriented File System?
- Why the Capacity Is Displayed as 250TB After I Mount My General Purpose File System?
- How Can I Migrate Data Between SFS and OBS?
- Can a File System Be Accessed Across Multiple AZs?
- Can I Upgrade an SFS Capacity-Oriented File System to an SFS Turbo File System?
- Can I Upgrade an SFS Turbo File System from Standard to Standard-Enhanced?
- How Can I Migrate Data Between SFS and EVS?
- Can I Directly Access SFS from On-premises Devices?
- How Do I Delete .nfs Files?
- Why My File System Used Space Increases After I Migrate from SFS Capacity-Oriented to SFS Turbo?
- How Can I Improve the Copy and Delete Efficiency with an SFS Turbo File System?
- How Do Second- and Third-level Directory Permissions of an SFS Turbo File System Be Inherited?
- How Do I Deploy SFS Turbo on CCE?
- Videos
More Documents
- User Guide (ME-Abu Dhabi Region)
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris Region)
- Introduction
- Getting Started
- Management
- Typical Applications
Troubleshooting
- Concepts
- Specifications
- Restrictions
- Networks
- Other Operations
- Change History
- API Reference (Paris Region)
- User Guide (Kuala Lumpur Region)
- API Reference (Kuala Lumpur Region)
- Glossary
File System Resizing
You can expand or shrink the capacity of a file system when needed.
Notes and Constraints
SFS Capacity-Oriented file systems support resizing, during which services are not affected. Only In-use file systems can be expanded.
SFS Turbo file systems support online capacity expansion, during which mounting a file system may fail and the connection being used for mounting will experience about a 30-second (max. 3 minutes) I/O delay. So you are advised to expand capacity during off-peak hours. Note that only In-use file systems can be expanded.
The capacity of an SFS Turbo file system cannot be decreased. You can purchase a new file system with a smaller capacity and migrate your data to the new file system.
General purpose file systems have no capacity limit and do not support resizing.
Precautions
The rules for resizing an SFS Capacity-Oriented file system are as follows:
- Expanding a file system
Total capacity of a file system after expansion ≤ (Capacity quota of the cloud account - Total capacity of all the other file systems owned by the cloud account)
For example, a cloud account has a quota of 500 TB. This account has already created three file systems: SFS1 (350 TB), SFS2 (50 TB), and SFS3 (70 TB). If this account needs to expand SFS2, the new capacity of SFS2 cannot be greater than 80 TB. Otherwise, the system will display a message indicating an insufficient quota and the expansion operation will fail.
- Shrinking a file system
- When a shrink error or failure occurs on a file system, it takes approximately five minutes for the file system to restore to the available state.
- After a shrink operation fails, you can only reattempt to shrink the file system storage capacity but cannot expand it directly.
- Total capacity of a file system after shrinking ≥ Used capacity of the file system
For example, a cloud account has created a file system, SFS1. The total capacity and used capacity of SFS1 are 50 TB and 10 TB respectively. When shrinking SFS1, the user cannot set a new capacity smaller than 10 TB.
Expanding Capacity of a Yearly/Monthly SFS Turbo File System
- Log in to the management console and choose Storage > Scalable File Service.
- In the file system list, locate the SFS Turbo file system you want to expand capacity and click Expand Capacity in the Operation column to go to the Expand Capacity page.
Figure 1 Expanding capacity of a yearly/monthly SFS Turbo file system
Table 1 Capacity expansion parameters Parameter
Current Capacity
Current storage capacity of the file system
New Capacity
New storage capacity of the file system
Constraints:- For a Standard, Standard-Enhanced, Performance, or Performance-Enhanced file system, the minimum expansion increment is 100 GB. A Standard or Performance file system can be expanded to up to 32 TB, and a Standard-Enhanced or Performance-Enhanced file system can be expanded to up to 320 TB.
- For a 20 MB/s/TiB, 40 MB/s/TiB, 125 MB/s/TiB, 250 MB/s/TiB, 500 MB/s/TiB, or 1,000 MB/s/TiB file system, the expansion increment is 1.2 TB, and a file system can be expanded to up to 1 PB.
- Enter the new capacity based on service requirements and then click Next.
- Confirm the resource information and click Submit.
- Complete the payment as instructed and return to the file system list. Click the name of the expanded file system and check that the capacity has been expanded.
Expanding Capacity of a Pay-per-Use SFS Turbo File System
Figure 2 Expanding capacity of a pay-per-use SFS Turbo file system
- Enter the new capacity based on service requirements. For detailed parameter descriptions, see Table 1.
- Click OK. In the file system list, check that the file system capacity has been expanded.
